Results 1 to 10 of 10
Thread: Muriatic Acid and Pump Pressure
    May 2016
    Latrobe, PA
    33
    So my TA was up to about 200 at one point this year. I have slowly dropped it by adding MA and then letting PH creep back up then add more MA. It is now down about 90 and am fine with that. But every time I add MA to the pool my pump pressure goes up one the next 24 hours to a point where it needs back washed. I haven't backwashed it just bump the pump and after a couple days of that the pressure stabilizes. Is this normal? Its not a big deal just wondering if this is normal.
    Thanks
    Dan
    Pool - Above Ground 24' Round by 52" Deep
    Filter - Hayward EC40C92S
    Pump - Hayward 1HP Pump
    Test Kit - Taylor K-2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Muriatic Acid and Pump Pressure
    How are you adding the acid? What kind of filter is it?
    30,408
    To my knowledge, TA has absolutely nothing to do with increased pressure in your pump.
    May 2016
    Latrobe, PA
    33
    Im adding the MA to the front of the return in a very small stream into the flow. It is a Hayward DE Filter.
    Duraleigh, it is when I add Muriatic Acid that I see a spike in my pressure of my pump over the next 24 hours.
    JoyfulNoise's Avatar
    May 2015
    13,180
    When was the last time you tore down the filter and completely cleaned it out. Your DE fingers could be all "limed up" (scaled with calcium) and in need of cleaning. It's unusual that it's correlated to acid doses as there's really nothing that would cause what you describe.
    Matt
    May 2016
    Latrobe, PA
    33
    It was a brand new pump and filter in May of this year. I have only back washed it 4 times all summer (after finding TFPC). So I have not opened it up this year yet. Was planning on cleaning it at the end of the season before storing for the year.
    May 2015
    13,180
    And when you backwashed, how much DE have you been adding back?
    Matt
    May 2016
    Latrobe, PA
    33
    4 lbs as directed by the manufacturer in the start up instructions.
    May 2015
    13,180
    Quote Originally Posted by damato300x7 View Post
    If that's the full charge, then you have likely overcharged the filter with too much DE. Backwashing rarely removes more than 50% of the DE in the filter so doing a full charge each time adds too much DE.
    Mu suggestion is you tear down the filter and clean it all out. It's not hard to do, probably will take an hour or two. It's a perfect Saturday morning project.
    Matt
    May 2016
    Latrobe, PA
    33
    Ok will do. Thanks for the help.
