Thread: Mulch or pea gravel?
    Jul 2016
    Milwaukee, WI
    14
    Now that our pool is installed, I have to start the fun process of putting back the dirt (I think that's called back fill?) and landscaping around the AG pool. I've done some googling to get ideas but I'm trying to figure out what is the best to put down around pool: mulch or pea gravel?
    Wasn't sure if there's some considerations to think about when doing either one. The only thing I know is that mulch will have to be maintained each year.
    Also, any tips on helping our grass grow over all the dang dirt that's all over our yard? Due to electrical and gas line trenching. It's basically sand now because we haven't had much rain and it's so dry...I'm so stressed with how tore up our yard is in that area. My husband and I don't know squat about landscaping. I included a pic in case it helps. I put tarp down to prevent the kids causing a big muddy mess (ignore ladder, I just put it in so it hasn't sunk yet). A deck will be built for some of the pool area (front part and half of the right side of pool).
    19,000 gallons AG (18x40)
    Hayward Voyager system w/ 1.5hp Matrix pump
    Install: 8/2016
    Hayward 200,000 Btu NG
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Mulch or pea gravel?
    mulch can float away and be a pain around the pool, you could use pea gravel easily or just grass up to the pool..
    grass is easy to grow, grass seed, fertilizer and water, lots of water
    Jul 2016
    Milwaukee, WI
    14
    Thanks!
    Install: 8/2016
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    We used river rock on top of landscape fabric and it works well. Only difficulty is walking on it with bare feet. So I have placed patio blocks evenly spaced around the pool on the river rock so I can walk around the pool to vacuum. We also used a metal edging as a barrier between the lawn and the pool rocks. It works well but must be deep enough to stop the grass roots from working their way into the rock bed.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
