Thread: Can't find what my Spa's make and model is?
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    I recently moved into a new house with an existing hot tub. As I'm trying to understand everything, I know that one of the first things I need to provide on a forum like this is the brand and model.
    Tell me if this is weird. There is no branding on my spa at all. Not on the control panel, not on the head rests and I don't see a badge of branding anywhere. There is a deck built around the base of it, but I can see three sides of it without crawling up under the deck and no indication of what brand it is. There is residue of a sticker on the front which I feel certain provided some information, but it is long gone. Any ideas on how I find out what kind it is?
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Can't find what my Spa's make and model is?
    It will likely be inside the service panel.
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    Thanks, are you referring to the electrical breaker box for the Spa that is mounted nearby on the side of my house? I don't see any markings there either. Or is there another service panel that is on the spa itself you are referring to?
    Memphis, TN.
    Taylor K-2006
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    One of the panels on the spa itself should come off to let you get in at the pumps. It should blend in pretty well, but look for screws holding it on.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    DFW, TX
    24,516
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    Thanks for the responses. The previous owner didn't build the deck in such a way that it's easy to get to that panel, so that's going to suck when I need to service it.
    Turns out it's an Artesian! Still surprised there's no branding on the tub itself, like near the temp controls or the headrests.
    Thanks again.
    Memphis, TN.
    Taylor K-2006
