Results 1 to 10 of 10
Thread: Extremely low (below4) pH, what to do, what caused it?
    Been lurking on here for last two years keeping my pool in check with all the knowledge in these threads but I can't figure this one out. Have a 24' 48" high above ground liner pool with a sand filter and intex swg which works great. Pools clear and clean. Problem is my ph read low on the quick test so I dumped in a bag of baking soda. Stil read below chart after a week so I took sample to my work with a proper pH meter and ph is below 4. What causes this and what's the best way to remedy it. Seems like a lot of baking soda to fix. Is a dump and refill in order? Thanks for any help.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Extremely low (below4) pH, what to do, what caused it?
    Welcome to TFP jabroni1m
    When was your last pH reading and what was it ?? What exactly are you using to test your pH at home ??
    Do you have an attached spa, waterfall, ...
    It would be very helpful instead of promoting your business you added your pool and equipment info to your signature as outlined here - - > Pool School - Getting Started
    Solar Blanket, Well Water, Borax Added. 68
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    From Pool School - Recommended Chemicals: "pH can be raised in three ways: borax, soda ash, and aeration."
    Baking soda is for raising TA.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    I'm not sure how "I'm promoting my business". No mention of a business name and my business is a winery not a pool company. But my "Business" does have several $2000 pH meters that are used daily so I'm positive on the pH reading. Tested it again yesterday and it was 3.9247 to be exact. My alkalinity was low as well so I thought I could kill 2 birds with 1 stone.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Your signature had a message about microscopes. But it's gone now. Weird.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by pabeader View Post
    do you need microscope to make wine nowadays? If it was about wine from the start I think it would get warmer response but microscopes ...
    In any event, normal signature content would be much more helpful.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    Quote Originally Posted by UN1017 View Post
    This is the answer to your pH problem Jabroni1M. Using PoolMath it will help tell you how much borax or soda ash to use. I would suggest the Borax as its easiest to find in the laundry aisle. I would do it pronto also as low pH is rough on vinyl and equipment.
    Donldson's Avatar
    NW Ohio
    2,880
    Stop.
    Before you do anything, what is your TA? Given your pH reading, I will assume it is zero or lower (yes, negative TA is a thing). Without bringing that up it will be very difficult to raise your pH and keep it there.
    Sent with Tapatalk on HTC Ten
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    30,400
    Welcome to the forum.
    Donaldson's got it right. (Isn't he annoying?) Baking soda first....regardless of how much it takes.
    Don't be offended by that. That block is used for information that us frequent responders must have (because we can't remember what each person has) if we are to comment intelligently back to you. Is it time to drain and refill? We don't know because that block is where we want you to put the size of your pool so we can answer that question.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    My fault for assuming The link took me off to some business so I figured . . .
    That and I didn't read your post close enough to notice it's an AG. So no attached spa and likely no waterfall. Sorry.
    When was the last time you had a normal 7.2-7.8 reading and how fast did it drop ?? Is there anything you've done lately that you think may have impacted the pH level ??
