Thread: confused about CYA and ph
    Aug 2016
    Lawrence
    4
    Hi all, long time lurker. Thanks for all the advice over the years. I have a new problem. Our pump motor died about two weeks ago just prior to going out of town. I was unable to receive a new pump prior to leaving. I tried to cYA levels tend to run high because we use cartridge filters and dont need to backwash so it just builds over the summer. We drained the pool halfway and are refilling. The levels are still near 100 and the ph is 8.8! Why would an algae blood cause the ph to be so high? I would think algae would produce acidic by products. Anway, more puzzling is the cya. I decided to test a clean sample of city water. cya=50! Is my city using stabilized chorine to treat our water? Is there another chemical in city water that reacts with the cya strip? Have others noticed this? Thanks in advance.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: confused about CYA and ph
    Welcome to TFP!
    Test strips are an unreliable way to test any pool chemical accurately and reliably. Pool stores that use electronic systems are just as bad as test strips for CYA and FC/CC levels. The only way to properly test for CYA and FC/CC is to use a test kit supplied with Taylor reagents.
    There is nearly zero chance your city water has cyanuric acid in it, especially at that concentration. Your strips are bad to start with and perhaps expired or compromised.
    Isolated Spa - 345 Gallons
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I haven't seen a post yet were anyone reported having any CYA in their tap/well water, other than this one.
    Welcome to TFP chiefgarner1
    Were you using strips to test for pH too
    Solar Blanket, Well Water, Borax Added. 68
    Aug 2016
    Lawrence
    4
    yes. I figured thats what it was. I have a taylor kit but ran out of the cya reagent. Thanks to both of you for your help!!!
    Feb 2014
    Central Minnesota
    5,080
    For quick chlorine testing, I would use a color match kit such as the K-1000 included with the Taylor K-2006 and the TF-100. That also is the best way to test pH with the K-1000.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Best place (IMHO) for those strips is the circular file
