Results 1 to 9 of 9
Thread: DuPont Restore splashed into pool, what to do?
    Jul 2012
    Whidbey Island, WA
    397
    Am having slate around pool cleaned & sealed. Contractor using product Dupont Restore.
    Not much but some splashes into the pool.
    Contains
    phosphoric acid
    glycolic acid
    alcohol ethoxylate
    Called distributor and their tech support said we know nothing about pools. Said I should call a doctor. Huh?
    So is a little splash in bad?
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    JoyfulNoise's Avatar
    May 2015
    13,231
    Re: DuPont Restore splashed into pool, what to do?
    It's fine. The glycolic acid and alcohol ethoxylate will break down from chlorine exposure. You do need to be careful around the pool though - a splash is ok but running off that stuff into the pool is no good. So tell the contractor to be more mindful.
    Matt
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I'm no expert but I'd try poison control and try to get a hold of the products MSDS on line.
    Less than a gallon ?? Less than half a gallon ??
    I'd sure leave the filter going 24/7 for now.
    Edit: MSDS - - > Google
    Solar Blanket, Well Water, Borax Added. 68°
    May 2015
    13,231
    Just to be a bit more specific, the glycolic acid is the only component that should concern you because it can breakdown in water and form oxalic acid which is toxic IN LARGE QUANTITIES (causes kidney failure due to stone formation). HOWEVER, the amount of GA in this cleaning product is 1-5% based on the MSDS and the product is typically diluted 1:1 for heavy cleaning application. So if some splashed into the pool, the GA would be heavily diluted and not to worrisome.
    As I said, tell the contractor to be careful. You might need to cover the pool while they work.
    FYI - DryTreat Eff-Erayza is a better product to use around pools as it is urea hydrogen chloride based which is easily broken down in pool water...
    Matt
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by Kiss4aFrog View Post
    called local poison control > they only have info on the product out of the bottle, not dilute in pool
    gotta be < ˝ gal
    will read MSDA
    thanks
    so informed contractor and he seems to be doing well
    also showed him printout on Eff-Erayza
    product also contains phosphoric acid? what about that one?
    May 2015
    13,231
    See these links -
    Dry-Treat | HANAFINN Eff-Erayza™
    http://www.drytreat.com/assets/pdf/S...ERAYZA_USA.pdf
    It's 50% urea hydrogen chloride (urea with a hydrogen chloride acid adduct) so it is an acidic based cleaner designed specifically to remove efflorescence. The HCl gives it low pH and the urea acts as a chelating agent for different divalent metals (Ca2+, Mg2+, Fe2+/3+, etc). HCl has no effect on pools and the urea will be oxidized (slowly) by chlorine to chlorourea and eventually broken down by sunlight UV.
    Matt
    Apr 2013
    Sacramento, CA
    2,769
    Phosphoric acid or vitamin B5 is harmless in these concentrations. You would get more exposure drinking a can of coke. It too will be broken down by the chlorine and be gone.
    Jul 2012
    Whidbey Island, WA
    397
    thank you all
    contractor is doing nice job, splash will be much < ˝ gal
    Jul 2012
    Whidbey Island, WA
    397
    I think contractor did well with the Restore.
    Next he sealed with Stonetech Enhancer Pro. This is organic so I guess did not mix with the water.
    A few splashes floated like transparent leaves and wound up in the skimmer.
