Thread: Where to start before SLAM
    Mar 2015
    Dallas, TX
    30
    My results as of about 6am this morning are below. My question is where do I start? I'm assuming adjust the PH first? What effect will that have on my other numbers?
    FC: 0
    CC: 0
    PH: 8
    TA: 60
    CH: 350
    CYA: the dot never disappeared
    This is a 30k gallon plaster pool. Standard DE filter and single speed pump. I have an older SWG that hasn't been used in a while (meaning the pool has been run as regular since we bought the house).
    Any help is appreciated.
    30,000 gallon IG
    Pentair FNS Plus DE Filter
    Single-Speed Pump (don't know make)
    Aqua Rite Controller w/Turbo Cell
    Jun 2014
    15,255
    Re: Where to start before SLAM
    You do need to lower the pH to 7.2 - correct. At the same time though, get some stabilizer in there ASAP for a beginning CYA level of 30.
    To increase CYA via granular stabilizer, place the required amount as calculated by the Poolmath calculator into a white sock and place in the poolside skimmer basket. For those concerned about suction flow to the pump, suspending the sock near a return jet or from a floating device will also suffice. Best never to allow undissolved granules to rest directly against the pool surface. Squeeze the sock periodically to help it dissipate. Once dissolved, consider your CYA adjusted to that programmed (target) level. CYA test readings should show a rise in 24-48 hours, however some pools may experience a longer delay to fully register. Best to confirm final CYA in about 5-7 days before adding any more stabilizer/conditioner.
    Once the pH is confirmed at 7.2, then increase FC to 12 and maintain that FC until you pass the 3 SLAM criteria. Hope that helps.
    Mar 2015
    Dallas, TX
    30
    Thanks. Sounds "simple" enough. Will get started this evening.
    So just a regular sock?
    30,000 gallon IG
    Jun 2014
    15,255
    Yes, but I'd use a white one.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Quote Originally Posted by Edd View Post
    Yep... tube sock type 1 each... Tie it off in front of the return and let it flop around until it dissolves..
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Mar 2015
    Dallas, TX
    30
    Thanks for everyone's help...
    30,000 gallon IG
