Thread: Question about heater use
    Jul 2016
    Milwaukee, WI
    14
    I'm a brand new pool owner. I've tried to google the answer but haven't found anything to answer.
    When should I run my heater so it's warm water to swim in during day? If it's over night, can I have it running with the solar cover on?
    Siggy shows my heater: 200,000 BTU Natural Gas (Hayward)
    Thanks
    19,000 gallons AG (18x40)
    Hayward Voyager system w/ 1.5hp Matrix pump
    Install: 8/2016
    Hayward 200,000 Btu NG
    Re: Question about heater use
    That's really half a question. We don't know what the temperature of your pool is and we don't know what you want it to be. For that size heater/pool figure on maybe 1 or 1.5 degrees an hour (probably closer to 1). Covering it will help retain heat. The risk of leaving it on overnight is that it's hard to predict where you'll end up temperature-wise and it may be warmer than you'd like.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
