Results 1 to 19 of 19
Thread: Green pool when filter was broken
    Feb 2016
    CYPRUS
    56
    Pool has gone green due to a part on the filter breaking, have finally got the part and installed it and filter back in operation. Whilst filter was out of commission I left the pool on recirculation and kept a check on the chemical levels, now that I have put the filter back in service will the water clear up or will I have to slam it? The filter has just been changed with glass as the medium and is virtually unused. Any help much appreciated It is the bigger of the 2 pools in my sig....
    10300 Gallon vinyl pool, 0.75 Kripsol pump, glass filter, Pool Exact EZ photometer tester.
    9500 Gallon vinyl pool, 0.75 Kripsol pump, glass filter, Pool Exact EZ photometer tester.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Green pool when filter was broken
    I would not have expected a pool to go green simply because of no filtration. What FC levels were you maintaining and what is your CYA? Were you still routinely brushing the pool?
    The pool will clear up, but you'll need to SLAM it if it's green.
    Isolated Spa - 345 Gallons
    Feb 2016
    CYPRUS
    56
    Unfortunately the pump has now failed and a new one will not be available until next Tuesday, I will wait for the pump and once installed I will start the slamming process.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    In the meantime you can always add liquid chlorine and brush to help maintain the water.
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,155
    I had to shut my pump down last year for a little while and would still put chlorine in, brush AND run my pool vacuum to keep the water and chlorine circulating. No green.
    Feb 2014
    Central Minnesota
    5,080
    As suggested, that's what I was getting at in my reply. A pool can be kept sanitized and algae free for weeks without a pool pump. It's just quite a bit more work. Must be brushed every day to maintain circulation. Running a robotic cleaner can help as well.
    Feb 2016
    CYPRUS
    56
    Thanks for the replies, unfortunately I do not live at the property and Algae has already formed, fortunately a new pump was fitted yesterday (Friday) I am now in the process of slamming it...
    Feb 2016
    CYPRUS
    56
    Slamming now in progress, pool has changed colour from a really dark green to a cloudy blue in 24 hours, will continue to slam until it passes all 3 tests for an algae free pool, thank god for this site, it is absolutely brilliant....
    Feb 2014
    Central Minnesota
    5,080
    Glad to hear that you can now attack that algae! Feel free to post test results as your progress. And pictures! Pictures are great!
    Feb 2016
    CYPRUS
    56
    These are the photos of the green pool, I am still slamming as the water has a slightly dull/cloudy appearance to it. It is nearly 2 weeks since I started the slam, is this normal or should the slam be complete by now?
    Screenshot from 2016-08-25 15:26:57.jpg20160814_112200.jpg20160821_102859.jpg20160824_101509.jpg
    Feb 2014
    Central Minnesota
    5,080
    Looks like you're getting close! It can take quite a while if the pool is fairly green. At this point, it's up to your filtration to get the water clear but you must maintain FC at SLAM levels during the process. What is meant by "glass" filter. Are you using a sand alternative in the filter? Have you tried adding some diatomaceous earth (DE) to the filter to enhance filtration? Pool School - Add DE to a Sand Filter
    Feb 2016
    CYPRUS
    56
    Hi, yes I have replaced the spent sand with crushed glass. My own pool filter was changed to glass last year and the water has never been clearer.
    Feb 2016
    CYPRUS
    56
    I have now concluded I have mustard algae, therefore I have raised the FC up to the figure quoted for slamming this type of algae. I have been in the pool today and had both the pool lights out, could not believe how much algae there was behind the shallow end light, both lights and niches are now spotless. Have been under the ladders with a fine tooth comb, so once again they are spotless. The pool is being brushed regularly during this time. I will continue this type of slam for 24 hours and then start to bring the FC down. Do I bring it down to normal levels or down to slam levels?
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Quote Originally Posted by dojoman59 View Post
    How did you determine that you have mustard algae? Mustard algae is very rare.
    Regardless, you do not raise FC to mustard levels until after you complete a standard SLAM.
    From the sound of things you are not even close to completing a SLAM (cloudy water, visible algae etc).
    http://www.troublefreepool.com/conte...-mustard-algae
    I think at this point you are just wasting chlorine raising it to MA level.
    Also, how are you testing, and please post recent results for FC, CC & CYA
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Feb 2016
    CYPRUS
    56
    Hi, thanks for the reply. I came to this conclusion after I had completed a slam. The pool passed all 3 criteria for the slam, but when I started bringing the FC level down, this algae kept appearing. I did loads of research online and the description For MA was identical to the symptoms in the pool.
    Feb 2016
    CYPRUS
    56
    I now have crystal clear water, the pool has passed all 3 criteria for the slam process. The mustard algae has gone and the pool looks like the other 2 that I look after. Here are my latest readings,
    FC 7.1
    CC 0
    TA 84
    PH 7.4
    CYA 47
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Great news!!
    Just a note: Sand has been around for millions of years and does not get old or break down. Occasionally, it does need a deep clean, but full replacement is only needed if clogged up and stuck together through the use of pool $tore potions.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Feb 2016
    CYPRUS
    56
    Hi, thanks for the reply, I did do a deep clean before I refilled the pool, however when I started to use the filtration system again the rubbish I was vaccing was coming straight back into the pool, that is why I opted for a glass medium. The pool builders here quite often do not use the correct sand for pool filtration but will tell you they have. The glass here is very reasonably priced, and since changing over to glass the water is keeping very clean.20160910_111440.jpgHere is the latest photo of the pool now....
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Pool looks great! I understand about the sand and your reasoning is solid. We had some issues what that last year and early this year. Sand that was labeled pool sand but was not properly sized for pool filter use.
