Thread: ethylene glycol and rubber
    Diver's Avatar
    May 2011
    South of Boston
    450
    I typically use an expandable rubber plug in my skimmer when I close my pool for winter. I pour good amount of ethylene glycol based antifreeze into it and stuff some pool noodles. Last year somehow I didnít get much additional water into it over the winter and antifreeze stayed undiluted. The top part of the plug had rubber all shriveled and misshaped. Which seems to be an effect from the ethylene glycol. Which is not a big deal, since a rubber plug is under $10 and can buy new ones every season.
    This upcoming winter will be my first one with solar system. I planned on adding some glycol to the pipes around check valves, 3 way valve and possibly bottom header of the panels. But now Iím concerned with rubber gaskets on the expensive valves and connecting rubber hoses between the panel that form the bottom header.
    I tried to find if glycol indeed reacts with rubber and it seemed to be a case. However there are tons of different rubber types.. So Iím wondering if anyone had an experience/knowledge with this and can share something thoughts. I found this page about rubber resistance, but not sure how helpful it really is:
    http://mykin.com/rubber-chemical-resistance-chart-3
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    JoyfulNoise's Avatar
    May 2015
    13,209
    The proper type of antifreeze for pools is propylene glycol (RV antifreeze) NOT ethylene glycol (automotive antifreeze). Please confirm you are using the proper kind of antifreeze because automotive antifreeze would create a toxic mess in your pool. Automotive antifreeze is typically iridescent green [EDIT] or orange[END-EDIT] while RV antifreeze is typically bright [EDIT] pink [END-EDIT]. The primary component of RV antifreeze should be listed as propylene glycol.
    Matt
    Diver's Avatar
    May 2011
    South of Boston
    450
    Re: ethylene glycol and rubber
    sorry, you're right. it's propylene glycol!
    looking at the chart (5th page on the link i posted for propylene), it looks propylene glycol is more corrosive than ethylene one...
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    JoyfulNoise you are correct except . . . RV is usually pink. Automotive Dex-Cool for GM's is orange. Small thing but don't want someone to make the mistake.
    Either one should be safe around rubber. The RV especially as it's used in the water system where there are usually rubber O rings, washers and gaskets. Not sure how either would react to the "noodle" ??
    Solar Blanket, Well Water, Borax Added. 68į
    May 2015
    13,209
    I had a moment of color dyslexia. I totally remember that RV is pink and that's the image I have in my brain but for some reason I wrote orange....oh well, I guess that's why I'm not allowed to dress the kids
    Matt
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Do I know that feeling (dyslexia).
