Results 1 to 8 of 8
Thread: Oval pool install question
    Jun 2016
    Taneytown Maryland
    29
    Hello, we are digging the holes for the braces of our buttress free oval pool. I was wondering is just 1 concrete block used to support the braces in the back or is another concrete block needed for the front as well? Thank you so much.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Oval pool install question
    I'm really not sure what the correct answer is, but perhaps a bump will get you the right answer. Likely too late, but hopefully not.
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Is this a Half of an "A" style leg, or just straight up and down?
    Jun 2016
    Taneytown Maryland
    29
    it looks like this thank you
    Apr 2013
    Sacramento, CA
    2,769
    What is the pool model?
    Jun 2016
    Taneytown Maryland
    29
    Its this one. Thanks
    Apr 2010
    East Texas
    9,655
    http://bluewaveproducts.com/manuals/...val_Manual.pdf
    There's a link to the installation instructions. Shows two blocks, one under each end, but not under the upright itself.
    Jun 2016
    Taneytown Maryland
    29
    Thank you so much. I was worried because I wasnt sure about it. I appreciate your help. Its alot more difficult to install this than what I had thought it was going to be because we have never set up a pool like this before.
