Results 1 to 8 of 8
Thread: Another...slightly cloudy blue pool
    Apr 2015
    Boston MA
    93
    Hi Folks,
    It has been a while since I've posted. We have been swimming quite a bit this summer in the new pool...my apologies.
    I have been testing regularly and results have been great. I have used Poolmath religiously and maintained as suggested. All good...until yesterday..
    The pool was used quite a bit at the weekend. I have only backwashed once this year...it's currently running at 15 psi.
    Here are my test results from yesterdays test.
    I will post in the forum now. Here are my results below....
    FC 4.5
    CC 0.5
    TC 4.5
    CH 75
    TA 110
    CYA 70
    PH 7.5
    CL/BR 2-4
    Salt 4600ppm...I know this is really elevated...I had just added water two hours before testing.
    I'm not sure what the problem is? High in Calcium?
    Here is a photo below....What steps do you suggest are next?
    Thanks so much for your help.
    15x30 Oval 13,500 Gal, IG Vinyl built Fall 2015,
    TF-100 test kit
    Pentair Sand Dollar 40 Pump & Filter System 1HP Dynamo
    Pentair Intellichlor SWG, Dolphin Nautilus
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Another...slightly cloudy blue pool
    Could your guest have had a lot f sunscreen or lotion on? I like to bump up my FC some before and after high swimmer load. If I were you, I raise my FC and do an OCLT.
    Apr 2015
    Boston MA
    93
    Great point about the Sunscreen. I had never considered that.
    In order to perform the OCLT test...do I need this kit? FAS-DPD test? If so, I do not have one...only the TF-1000
    TF-100 test kit
    30,401
    If you have a TF-100, you have the FAS/DPD test included.
    Apr 2015
    Boston MA
    93
    Did the test. OCLT still the same over night. I performed a backwash, added new water and adjusted the chlorine levels.
    Pool looks great. I will do another full test tonight and post the results tomorrow.
    I appreciate your help Duraleigh and PAgirl.
    TF-100 test kit
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by derryank View Post
    No problem, that's what we're all here for!
    Dec 2014
    Santa Ana, CA
    523
    you turned off your SWG for OCLT and left pump running, did you? If SWG was 'on' the test is invalid- pool should have no chlorine source during the test and still lose less than 1ppm FC.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Apr 2015
    Boston MA
    93
    Quote Originally Posted by max2k View Post
    OH? I did not...thanks for this information Max2k!!
    I will perform another test tonight....I love the help on this forum
    TF-100 test kit
