Thread: Powdered Chemicals and Intex Pools
    May 2009
    Corning, CA
    22
    I have seen it mentioned in a couple of posts to avoid putting powdered chemicals directly into Intex pools because they are not very deep. What would be a good method for doing this? Dissolve in a 5 gallon bucket of water and pour into pool in front of the pump return? Can the same bucket be used for pH Plus and pH Minus (rinsed in between uses of course)? What about the powdered "shock" products?
    Thanks.
    Dave
    Intex Easy Set 18' x 42" AG
    5400 gal
    Intex Krystal Clear Model 635 pump, 1500 gph
    Type "A" cartridge filter
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Powdered Chemicals and Intex Pools
    Yes ph +/- use the bucket. I don't use powder shock so can't say for sure. Best best and cheaper to get away from pool store chems.
    pool-school/recommended_pool_chemicals
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Cal-hpo you can predissolve in a bucket and pour in front of the return.
    I would not use the Dichlor powdered chlorine at all. Better to just use bleach.
    May 2009
    Corning, CA
    22
    Thanks for the replies. I am not using the powdered chlorine. I am using the hth Trichlor tabs. Will probably continue until the CYA gets into range. After that . . . who knows. Give it away to a friend who uses them in his pool. Although I feel kind of guilty about that. He is a "7 tab every other day" guy plus pH+, pH-, algaecide and clarifier once a week, with the 2 way test kit. Not really open to suggestions as he is convinced that's the way to do it. I figure if it works for him, I'll just let him be. If he asks, I'll certainly tell him about TFP.
    Just ordered the TF100 test kit so soon I will know what the CYA level is.
    Ordering the test kit was easier when I put it into perspective.
    Pool $250
    3 yds of sand delivered plus ground cloth $192
    Bender board, stakes, etc for pad frame $100
    Assorted chemicals ??? don't know. Wife picked them up at Walmart and I didn't see the receipt
    Test kit $68 pretty cheap insurance
    Oh . . . and to continue in the VISA commercial pattern . . .
    Having sparkling water that is safe for my kids to swim in . . . PRICELESS
    Dave
    5400 gal
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by DDave
    Some people (including me) view the bucket of tabs as a lifetime supply of vacation chlorine. Load up the floater and take off for a week... the extra CYA from doing this 1-2x per summer is not going to be a problem.
    --paulr
    BBB "Intermediate Swimmer"
