Thread: Several Different Questions
    Jul 2016
    Whitesboro, TX
    85
    This is my first year with a real pool. (Literally before they were all the plastic kiddy pools...lol) I have had a whole lot of trial and error this summer until I found this forum and I value your feedback. I could be completely off on some of my thinking so feel free to correct me. I am trying to make a complete list what I want to do and buy during the winter and early spring to be ready for the 2017 opening of my pool.
    Currently I am running the factory cartridge filter pump that my pool came with which is honestly a hot mess. My pool has two inlets and no in the wall skimmer. I know I am going to buy a Hayward SP1091LX Dyna-Skim Above Ground Pool Skimmer and Accessory Kit and install it at opening. So I am thinking that I will have three hoses or pipes running from the pool to combine to the pump in one. I have also been reading where people converted their inlets to 1.5 inch openings which I would like to do to increase the amount of water that is able to circulate. I will be vacuuming with my Pentair Kreepy Krauly Lil Shark from the skimmer. Should I only use one 1.5 inch inlet and close the other one off since I will be adding the in the wall skimmer or leave them all going? Or should I just leave them at the regular size since there are two and still add the skimmer? (So many options is making my head explode...lol) My reason for asking is I want to make sure that the vacuum is getting enough suction. These are the two pumps I am looking at and I have no experience with sand filters. I am wondering if the first one is too big but maybe not with two inlets and the in the wall skimmer. If I can use the bigger one then I would like to because eventually we will probably up the size to the 26' one but that is years away.
    https://www.amazon.com/dp/B007TNRUUE...I16ZF3QAT98P9A 4500GPH 19" Sand Filter with 1HP Above Ground Swimming Pool Pump made by XtremepowerUS
    https://www.amazon.com/dp/B002V1H11W...I1LQ64UZEIGBIN Intex 3000 Gallon Sand Filter Pump
    While we are at replacing the pump we will go ahead and hard plumb it for even better results. I would also like to upgrade the return fitting since mine just blasts out. I would like to point it to the side so skimming is easier from what I have read. This is what I have found but I am not sure if this is what I need or not.
    https://www.amazon.com/Complete-Pool...fittings+intex
    I will also be draining my pool to redo dirt work, smooth out the liner, and lower my CYA because in the beginning I was being pool stored....Grrrrr! Also any advice on a SWG that would pair well with this setup would be appreciated because I haven't even begun the research on that one. Sorry I posted such a mess of questions but I felt it was important to put them together since one affects the other.
    Gina
    22' Round x 52" deep Coleman AGP, 12,500 gallons. Filled 5-1-16. XtremePowerUSA 4500 GPH 19" Sand Filter w/1.5 HP Pump. Hayward Dyna-Skim In The Wall Skimmer. Hard Plumbed w/2" PVC. PVC Aerator. Pentair Kreepy Krauly Lil Shark Above Ground Pool Cleaner. Whitesboro, TX (North Texas). Taylor K-2006 Test Kit Comp Chorine FAS-DPD. Use The Pool Math App By Trouble Free Pool For Logging.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Several Different Questions
    What great questions
    You are wanting to do exactly what I did.. You can use the skimmer and 1 return as suction and the other 2 openings as returns.. with the extra suction you can have a suction side cleaner attached all the time if you want..
    these are a little better fitting, you will need to cut them out like I did though.. Amazon.com : Hayward SP1023G Vinyl Fiberglass Inlet Fittings for Pools, Spas and Hot Tubs : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    as for the pump and filter, I like the first one except I would get a 2 speed pump, I run my low speed 11.6 hours a day and run high speed 20 minutes.. but as you have probably seen, it gets more expensive when you buy the pump and filter separate..
    SWG: I really love the curcupool SJ model, they are cheap and do everything needed without all the bells and whistles, you also get the next bigger size for a dollar..
    Full Market Comparison of Salt Water Chlorine Generators for Swimming Pools
    CircuPool® SJ-20 Salt Pool System
    I hope this helps
    I posted these for someone else yesterday and figured it would help you also
    Jul 2016
    Whitesboro, TX
    85
    Wow! That's my dream setup! Thanks for all of the pictures! I will have to really look them over once the kiddo goes to bed!
