Results 1 to 10 of 10
Thread: Yet another aeration in progress
    Meadow's Avatar
    Jun 2016
    Temecula, CA
    224
    With TA at 90, I have been adding MA every couple of days and decided to automate using Stenner. But I learned from other members here that they don't add MA often as I do. Figured I should take the aeration approach. Unfortunately, improvising nozzle attachment to the returns is not an option in my case. So I bought an inexpensive 1/3hp sump pump to use. Grabbed some PVC and 1" fittings from Lowes. Altogether is less than 60 bucks, since I have left over PVC glue.
    I have no idea where to aim the nozzle to speed up the process but here’s what I’ve done.
    First photo, PH climbed from 7.2 to 7.6 in 24 hrs.
    I decided to add more holes at 45 deg angle in between and aimed upwards to shoot for more air. This indeed speed up the process, at least for me. PH climbed from 7.2 to 7.6 overnight.
    In less than 2 days, my TA went down from 90 to 60. I brought down PH to 7.4 and will observe. I may have to put the Stenner out of commission if PH will stabilize.
    Full test results:
    FC = 7
    CC = 0
    PH = 7.4
    TA = 60
    CH = 300
    CYA = 50
    Salt = 3000
    20k gallons, IG plaster with raised Spa, Hayward C-4000 cartridge, Hayward TriStar SP3202VSP, Hayward H400 gas heater, Hayward Super II (2HP) Spa jets, Hayward Swimpure Plus T-15,
    Intermatic PS3000 SPD, PureLine-PureColor LED's, Dolphin Triton cleaning robot, Taylor K-2006, K-1766, OTO Test kit & various Guess strips.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,234
    Re: Yet another aeration in progress
    That worked very well! I have similar numbers and would like my pH to drift up to 7.8ish and stay there longer.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,423
    Nice write up and sharing of info. on how you added more holes and at what angle to speed things up!
    That is a pretty pool!
    blata's Avatar
    Aug 2016
    ellisville, MO
    10
    Interesting. About 5 days ago I made an aerator that screws into a return. It's just below the surface but brakes and arcs about 12 inches out of 8 7/32 holes . I also added MA to bring my TA down. 1 gallon to go from 130 to 120 and ph of 7.8 to 7.2. It's been 7.2 since. Wonders to self what I'm doing wrong.
    Nice pool btw.
    22k Vinyl IG ~15 years old, Hayward s244t Sand, Pentair Superflo vs , Hayward Navigator, and Taylor k-2006
    Ipsa scientia potestas est
    Meadow's Avatar
    Jun 2016
    Temecula, CA
    224
    Thank you all.
    Quote Originally Posted by blata View Post
    Nice pool btw.
    Am I understanding your PH is stable at 7.2? I am jealous!
    Well, now my TA is at 60 but PH still creeps rapidly from 7.4 to 8.0 in just 2 days. I had to add 24 oz of MA to bring down PH this morning.
    I am not eliminating the spillover as the culprit but I have long since reduced the amount of water flowing through by 50%.
    Now I am all ears to find that "sweet" spot for TA,... up or down more?
    needsajet's Avatar
    Jan 2016
    4,234
    Leave it right where it is and see how it goes over a few weeks. Going well!
    And don't fight the pH. Keep 7.6 - 7.8. With an injector, you can probably fine tune to 7.7/7.9
    Next thing to change will be CYA. If you have a holiday coming up, leave it where it is. Other start thinking 70 ppm CYA.
    This is a good article: Pool School - Water Balance for SWGs
    Could you change your signature maybe, Is Hayward SWP15 your saltwater chorinator? If so, is it a Hayward AquaRite T-15? If so, you could enter AQR T15 SWG or Hayward T15 SWG
    Going great. Well done!
    blata's Avatar
    Aug 2016
    ellisville, MO
    10
    Quote Originally Posted by Meadow View Post
    Yep it's been 7.2 for a week, but I've been adding about 3qts of bleach a day as I dont have a swg. So I guess its MA and pH with swg or bleach and FC without but your going to add something.
    blata's Avatar
    Aug 2016
    ellisville, MO
    10
    Wait a minute. Don't you use aeration to rase pH?
    "To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH." that's from the poolcalculator.com
    page in the TA section. So wouldn't your creeping pH be a result of your aerator or am I missing something being new to this whole thing?
    Last edited by blata; 08-12-2016 at 04:07 PM. Reason: trying to get rid of attachment
    Meadow's Avatar
    Jun 2016
    Temecula, CA
    224
    Cool Re: Yet another aeration in progress
    Quote Originally Posted by needsajet View Post
    Thanks needsajet. Yeah, I guess I could but that would steer away from what I actually have. I could swear I ordered Hayward AQRT15 but what I received is SwimPure Plus model SWP15. I was ! But according to the Supplier, I have to consider myself lucky to received the newer version of Hayward AQR series. Hence, relabeled as SwimPure Plus. Made me feel better, after all.
    Been there, done that! I stopped aerating 4 days ago when TA hit 60. Thanks
    needsajet's Avatar
    Jan 2016
    4,234
    You did well! Excellent
