Results 1 to 15 of 15
Thread: Best test kit ?
    Jul 2016
    slidell
    58
    Best test kit ?
    Can an experienced person advise whether to get the taylor K - 2005 or the TF - 100 Kit? Not sure from product descriptions if either will test for CYA ? thanks
    Blue haven kidney style 16,000 gal gunnite including Spa, test Kit TF - 100
    Built 2000 deep end 7.5 feet, 2 steps at shallow end
    Original SWG then convert to chlorine
    Pentair Clean & Clear cartridge filter (4)
    Blue Haven Teledyne Laars Platinum II heater
    Dec 2014
    Santa Ana, CA
    523
    Re: Best test kit ?
    Quote Originally Posted by 63john View Post
    TF-100 hands down + speedstir
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jul 2016
    slidell
    58
    Re: Best test kit ?
    TF 100 + speedstir will test for CYA ?
    JoyfulNoise's Avatar
    May 2015
    13,264
    Re: Best test kit ?
    The Taylor kit you want is a K-2006, not a K-2005.
    The TF-100 is a special/custom kit made by TFTestKits.net that uses the same reagents as the K-2006 but packages them in different quantities so you get more of the reagents you use the most.
    Both the K-2006 and TF-100 can test for CYA.
    If you have algae issues and need to SLAM a pool, then you want to get the Taylor K-2006C ("C" is for commercial grade, all reagents come in 2oz bottle sizes) or the TF-100 with XL option.
    A SpeedStir makes testing convenient and easy as it frees you hands up from having to swirl test tubes.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Best test kit ?
    I use the TF-100. More here, Pool School - Test Kits Compared
    Dec 2014
    Santa Ana, CA
    523
    Re: Best test kit ?
    among many other things and it's the best value. K2005 has limitations besides CYA which will force you to buy extra tests ending up with mix of tests you need to carry around. I prefer things to be in 1 box. I went with different kit at the beginning (K2006) and while great TF100 beats it in the long run.
    Jul 2016
    slidell
    58
    Re: Best test kit ?
    thanks Walmart (online) has a special mark down from $ 59.99 to 46.49 (no store pickup free shipping) on the K 2005 so just wondered.
    Dec 2014
    Santa Ana, CA
    523
    Re: Best test kit ?
    I wouldn't go with it due to its limitations but it's your call.
    May 2015
    Land O Lakes, FL
    527
    Re: Best test kit ?
    Get the speed stir too, you won't regret it
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Best test kit ?
    Also remember these pool test kits are sensitive to storage conditions and have a limited shelf life (24 months from date of production), do you trust Wal-Mart to have fresh kits stored in climate controlled locations?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,287
    Re: Best test kit ?
    The K-2005 does not have FAS-DPD chlorine testing, so it's not a good choice for TFPC. K-2006 has FAS-DPD but people recommend the TF100 the most
    TFTestkits.net
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jul 2014
    Europe / The Netherlands
    96
    Re: Best test kit ?
    Combine speedstir with the sampler sizer TFTestkits.net
    Arctic Spa Klondike Legend SE
    AG / Filter Cardtrige 50m2/ TFP / borates / TF100
    478 gallon @ 99.5-103.1 F Depending on season
    Ozonator disconnected
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Re: Best test kit ?
    This time of year I would expect Wally World to have fresh chemicals on the shelf they want to get rid of before fall. So a good price on an INCOMPLETE test kit. Just saying...
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    maddscot's Avatar
    May 2016
    McKinney, Texas
    9
    Re: Best test kit ?
    I, as others, cannot live without my speed stirrer (well I could but for only a short time). The TF-100 kit is great and has fantastic support.
    What I got - 14,000 gallon, above ground, plaster, Jandy 60sqft DE filter, Jandy variable speed e-Pump, Built 4/2016, Spa, Polaris 280 pool cleaner w/ dedicated pump, Jandy 400k BTU heater, wireless, sheer descents (5) & waterfall from spa to pool
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: Best test kit ?
    TF-100 for sure, and include the speedstir, you won't regret it. Best customer support by far too.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
