Thread: Desired output problem on AquaRite
    Nov 2012
    Tennessee
    68
    I have an aquarite with T-cell-15.
    Previously worked reasonably well for a few years it seemed.
    This past summer I have had problems with erratic chlorine levels-- levels drop to FC of 1 or less. I've tried many different things to remedy this.
    One thing that stands out to me as a problem is that the desired output I choose on the knob/dial does not match what shows up on the LCD display-- it used to line up pretty well: put the dial at 50%, the LCD said 50% (close enough)-- at least that's what I remember it doing, isnt' that how it is supposed to work?
    What happens now is that the dial can go from 10% to about 75%, while the LCD goes from about 1 to 10%--- So the dial will be at 75% and the LCD will say 10%, then if i turn just a bit further, say to 80% on the dial, the LCD suddenly reads something like 98%. Usually with some clicking sounds.
    Anyone dealt with this before?
    The cell in use is not much more than 2 years old (bought in 2014, not sure what month off hand). I've cleaned the cell with acid per manufacturer recs.
    I've replaced the board twice in the past 3 months, yet the problem persists.
    All help appreciated.
    Thanks
    Desperately seeking pool.
    Re: Desired output problem on AquaRite
    It’s probably a bad display board. What board did you replace?
    Support the site
