Results 1 to 14 of 14
Thread: Brand new build but Pump not working.
    Jun 2016
    St charles
    28
    Finally got everything hooked up and tried to prime pump but it won't. I have pool about half filled and wanted to make sure it was all working (plumbing) before backfill and concrete. I put the hose in the basket of pump and it keeps filling up pipe to main drain.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,490
    Re: Brand new build but Pump not working.
    K,
    How about more information about your pool and equipment. Is this an in-ground pool?
    A picture of your equipment pad would be great.
    Jun 2016
    St charles
    28
    Sorry 20 x 40 in ground 2" pipe. 2 main drains two skimmers. 2 hp pump
    Jun 2016
    St charles
    28
    Quote Originally Posted by Kfkruse View Post
    Jun 2016
    St charles
    28
    Try again
    Jun 2016
    St charles
    28
    Try again
    3 lines in 3 lines out
    Jul 2014
    Bedford, TX
    7,490
    K,
    Thanks for the pics.. So, since your pool is only half full, I assume you have the valves set to pull water from the main drain only. Water poured into the pump basket will quickly flow backward into the pool through the main drain as the water level is way below the equipment pad. I think they call it gravity...
    I recommend you fill the water up to allow water to enter from the skimmers also and see if that makes it easier to prime.
    But, generally, when a pump will not prime it is because of an air leak at the pump basket lid or, in your case, at the PVC union right in front of the pump. Suggest inspect the O-ring in the union and make sure it has plenty of "pool lube". Then do the same for the gasket on the pump basket lid. I've had this same pump and the pump lid gasket can get crushed out of shape pretty easy.
    After your inspection, turn the pump on while at the same time running a garden hose (on low) over the union and pump lid. If they are leaking air the water from the garden hose will fill the leaking area and cause the pump to prime.
    Give that a shot and let us know what happens.
    If the pump motor is running, I doubt that the pump itself is bad.
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    353
    It looks like the backwash discharge will flush the pump off the pad. A hose or pipe might be advised to direct the water elsewhere....
    A check valve between the pump and the intakes might also be an assist.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Jun 2016
    St charles
    28
    Quote Originally Posted by Vickery View Post
    That was a temp job but I totally see what you mean
    Jun 2016
    St charles
    28
    What is a check valve
    Jun 2016
    St charles
    28
    Quote Originally Posted by Jimrahbe View Post
    K,
    Jim R. Ur the best. Your comment made me laugh and go "ahhhhh that makes sense". What is pool lube though
    Jul 2016
    Marblehead, Ohio
    4
    The valve configuration is drawing from all locations. Check out the valve positions. A check valve allows flow of water in one direction and not the other.
    17,000 gal, 27' AG, Cartridge filter, Waterway 1.5 hp 2 speed pump, No SWG
    Jul 2014
    Bedford, TX
    7,490
    K,
    Leslie's calls it "Pool & Spa Lube". Looks kind-of like Vaseline, (do not use Vaseline) and it is used on all O-Rings and gaskets to prevent leaks. Many other brands. If you are not using it, that could be the cause of your priming issue.
    Jun 2016
    St charles
    28
    Thank you. Will pick some up today
