Thread: Foam padding under ladder legs
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    340
    i was curious if it would be ok if i were to put some of that anti-fatigue foam padding under the legs of my ladder inside of the pool? I am getting a little indention under my legs. i am afraid if i keep going with nothing under the feet i am going to hurt my liner.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Re: Foam padding under ladder legs
    Yes, that would be fine. The chlorine will eventually break down the material, so you may have to replace it when needed. I actually check carefully in my liner pool to make sure that legs do not put indentations as well. The ladder has plastic caps at the end and so far so good.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    chayne's Avatar
    May 2016
    340
    mine has those caps also, but i am still getting slight indentations. just dont want to ruin my liner. next year will not have this problem. will be doing alot of ground work before i put the pool up. bought this one off of OfferUp and just basically put it up. wished i had found this website first.
    Charles
    Coleman 16'x48"
