Thread: SWG and control board back to life
    Pepo's Avatar
    Mar 2015
    Orlando, Florida
    12
    I just install my repaired T15 cell and the control board, have both unit repaired and are working like new....Happy camper here, swg working again and saved some money in the process!
    15k Gal. ig Pool & Spa quartz plaster, Hayward super pump II 2.5 HP, Hayward 425 sf. cartridge filter,
    PS-4 Goldline automation, SWG(not working) using liquid chlorine now, Hayward 250k BTU propane spa heater.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,480
    Re: SWG and control board back to life
    Hi Pepo,
    Tell us more.. Did you do the repairs yourself or did you send them off somewhere. Give us the details in case someone here comes up with the same problem.
    Pepo's Avatar
    Mar 2015
    Orlando, Florida
    12
    Hi Jim
    They are located in tampa they refurbish the cell just reuse the outer shell and the cable everything inside is brand new, on the boards they replace the K1 relay and some kind of resoldering. They do one year warranty.
    You can check out at
    saltsolutionsinc.com
    not sure if I should write the website here, remove if necesary.
