Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Slam
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Slam
    Hello all, first post here.
    My question is can you swim during the slam process if the water is cloudy?
    Fc 30
    Cc .5
    Ta 80
    PH 7.4
    Cya 70
    Water temp 78
    Thanks in advance for any and all help
    Jim in ny
    A 46 year old man,wife,and twin boys doing the best we can.
    New install of an intex 12x24X2 rectangle set 18 in the ground.
    An intex 3000gph sand filter and an intex 15000 gal swg.9500 gal. Taylor 2005 and Taylor k-1515
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Slam
    Safe to swim up to SLAM value of FC for your CYA level. BE SURE you can see the bottom! Especially with little ones.
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    Just one more question please, when you pass the overnight test will the water just turn crystal clear or do you have to wait until the chlorine values to come down before it gets crystal clear?
    Apr 2010
    East Texas
    9,600
    Re: Slam
    You may not get crystal clear until your filter cat he's up with all the dead particles.
    Dec 2014
    Santa Ana, CA
    523
    Re: Slam
    Quote Originally Posted by jimmy88 View Post
    it really clears up after you & filter remove all dead algae from there. With sand filter this cleanup usually takes several days.
    please get one of the recommended test kits before you start the SLAM (or put its name in your signature). The SLAM is multi- day process where you have to maintain FC at shock level for your CYA so the good test kit is prerequisite for success.
    try to take 'progress' pics over stairs or any other feature providing gradual depth view. If you take them at the same spot/same lighting conditions it makes it easy to see how it goes. Make sure your SWG is off and your pump/filter is on 24/7, brush as often as you can. Good luck and don't hesitate to ask questions .
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    Does back washing help? 3000 Gph. Sand filter intex.
    Gotta fix that
    Dec 2014
    Santa Ana, CA
    523
    Re: Slam
    Gotta fix that
    backwashing helps when the filter gets clogged with stuff (+15 psi relatively to 'clean' pressure). Backwashing too often actually decreases sand filter performance, they work the best being slightly dirty.
    Apr 2010
    East Texas
    9,600
    Re: Slam
    Backwash when pressure rises 25 percent of normal pressure.
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    1470780690484459456069.jpgfirst picture,a and I started to maintain about 30fc Sunday afternoon. It was just starting to get dirty green,not bad though. Now it looks blue with a little cloudy.
    Thank you everyone for the input.
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    What stage would you say I'm in?
    Dec 2014
    Santa Ana, CA
    523
    Re: Slam
    you need to say that by trying to measure your overnight FC loss- part of OCLT. It will take some time for your sand filter to make it completely clear but FC overnight loss test will tell you right away.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Slam
    Quote Originally Posted by max2k View Post
    As woodyp said in post #8 you want to backwash when your PSI is 25% above your normal clean pressure. For example my clean pressure is 12, I don't backwash until about 15/16. But if I see above 16, definitely I backwash.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    Wow didn't know that about backwash I have been doing it twice a day.
    Thanks again
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    Like magic. Passed overnight test and water crystal today. I'll post picture later. Gonna keep it up at shock value one more night and make sure it passes again. No cc values either.
    Then what, how do I lower chlorine values?
    Thanks again everyone
    Apr 2010
    East Texas
    9,600
    Re: Slam
    Sun will lower it fast enough
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    Hello again, testing last night 9pm fc31 woke this morning 5 am tested fc34ppm,
    What could be the deal?
    Maybe I misfire this morning 68 is a lot of drops to count.
    Water is crystal clear today. I will run overnight test again tonight.
    Any thoughts?
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: Slam
    Is you SWG running overnight?
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    No it has been off since I started slam.
    Now it is staying off until chlorine levels come back down.
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    5pm readings,
    Ph. 7.5
    Ta.100
    Cya 60
    Fc 25.5
    Cc 0
    Still crystal but man can I feel the chlorine.
  20. Back To Top    #20
    jimmy88's Avatar
    May 2016
    Long island, N.Y.
    30
    Re: Slam
    One more question please , should I wait for chlorine levels to get to 6 to 8 ppm before adjusting my ta and cya?
