Thread: Trip advice, 2 weeks away from the pool.
    Oct 2015
    Dallas
    123
    Needed some advice on how to go about this. In Texas, heats probably 100 in early September. Have a variable speed, a solar breeze, 280 Polaris, spa, pool, 3 drain options (skimmer, spa, pool).
    my ph seems to always want to rise and I put in about 15 oz of muratic acid a week. I don't believe I will need to bother with pool pucks as I have a Stenner pump on a schedule running. I'm pretty widely estimating I'm using about 20 to 30 oz of chlorine a day.( Walmart brand).
    i am planning on doing two things. First, store the solar breeze in the garage. It does not need to be out. Second, cut off the top skimmer drain so if the pool dries up below the skimline the pool doesn't suck air into the pump.
    am I missing anything? It's a 2 week trip.
    Inground Gunite/Plaster pool with spa. Estimated 31,000 gallons.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,448
    Re: Trip advice, 2 weeks away from the pool.
    Pemolis,
    I was gone three weeks and my SWG kept the pool crystal clear. I think your Stenner will do the same thing. I did not think about just using the main drain, good idea. I just had a non-pool neighbor stop by and add watter once a week if needed.
    I increased my SWG's output based on increasing temperature forecast. A little extra chlorine is better than too little.
    Oct 2015
    Dallas
    123
    Ok sounds good thank you.
