Results 1 to 8 of 8
Thread: Waterproofing a new pool
    Jun 2016
    Spring Texas
    18
    Question Waterproofing a new pool
    Has anyone had any experience with water proofing their new gunite pool prior to plaster? Or if anyone is a builder and has knowledge of it, or if anyone has been pitched by a builder that has knowledge. I unexpectedly had additional time waiting for plaster and have started researching doing a waterproofing of the entire pool. Thoughts?
    Started 7-12-16 - O/B approx 20k gal pool, 35x25 geometric pool, wetedge primera stone, 360 zero edge raised hot tub, split face weeping wall with fire bowls!! Undecided on final equipment. My build here Spring TX - O/B - Looking for my deep blue horizon!!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Waterproofing a new pool
    With what? The plaster does that.
    Whatever you do, talk to your builder first, or you could void the warranty before it even begins.
    Dolphin E10 Cleaning Robot.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,517
    I had some weeping that was keeping my PB from applying the plaster. He said that they have a product that he could spray on the gunite that would stop any water penetration.
    He put on four coats before he gave up.. It did nothing. Sorry, but I'm not sure what it was. If it was needed or added any benefit, I'm sure every pool builder out there would be pushing it.
    As borjis says.. "That is what the plaster is for.
    Apr 2015
    tucson, arizona
    1,121
    Nov 2015
    Woodland Hills, CA
    176
    I applied a waterproofing membrane behind the waterline tile after the mortar was floated out and before the thinset.
    It was recommended by Laticrete for glass tiles only. Not the whole pool.
    O/B Woodland Hills, CA : O/B12x30 inground with 6x6 10-jet spa, 10,500gal, 6' Baja deck, 42" spillway, All Jandy: 400k heater, 2.7 HP VS pump, 1.5HP booster spa pump, SWG, Intellelink controls, (4) LED lights, cartridge filter and BlueSquareQ360 infloor cleaning system, Eclipse drain, glass tiles, Zanzibar white pebble finish. Broke ground 2/18/2016, completed 8/16/2016. TFT 100 kit.
    Jan 2015
    las vegas
    92
    We typically use waterproofing for specialty jobs. An example would be a roof top pool of pool partially above grade. Depending on the builder often times weir walls/negative edge walls are also waterproofed. Waterproofing will not hurt so long as the proper type is used. Depending on the manufacturer they have products for positive side and negative side pressure and some will work in both cases. Pool plaster is not a waterproofer, I am of the opinion that waterproofing used properly is of great benefit.
    Quote Originally Posted by lasvegaspools View Post
    I agree with the above completely. I have raised walls and a negative edge pool. I did my own research and found that negative edge pools can develop problems with the walls being wet and then drying. I had my entire gunite shell waterproofed.
    This is one of the articles I looked at:
    Avoiding the Pitfalls of Vanishing-Edge Pool Construction - AQUA Magazine
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Fascinating. I see now where that would be very important.
    Negative / infinity edge pools look amazing.
