Thread: Losing water quickly when the pump is running
    Aug 2016
    Canton/GA
    2
    Exclamation Losing water quickly when the pump is running
    Hello All!
    First post - long time pool keeper but first time with a DE Filter and in a new house so trying to get a handle on things
    First few days the pool/pump seemed fine but today my auto fill just kept running, the pump is losing prime, there is water in the sight glass which doesn't seem right. I suspect it's pumping down the drain line? and I need a new multi-port valve?
    Thanks!
    Craig
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,537
    Re: Losing water quickly when the pump is running
    Hi Craig, Welcome to TFP,
    If it is not obvious where the leak is, then what you say makes sense to me. Assuming it is bad, you can repair most multi-port valves by just replacing the spider gasket. Sold at most pool stores.
    Pretty easy to open and check. The spider gasket is in the bottom of the valve and you can see where it divides valve into different sections. It should not be loose or broken.
    Aug 2016
    Canton/GA
    2
    Thanks Jim! you nailed it. Opened it up and sure enough the gasket was torn into the drain section. Previous owner must have lost an insane amount of water!
    -c
    Jul 2014
    Bedford, TX
    7,537
    Craig,
    Perfect!!! Glad I could help and thanks for the feedback.
