Thread: What's eating all the chlorine I put in?!
    Aug 2016
    Asheville, NC
    13
    I wrote last week about maintaining our pool myself with all your help, but hadn't received our test kit yet.
    I just received a missing component of the TFTestkit I ordered and promptly tested our pool.
    FC 0.5
    CC 1
    TA 150
    pH 7.8
    CYA 70
    Borate 0
    CH 300
    For the past week, I've been adding a gallon of chlorine/ day, but it's obviously not enough.
    The calculator says to add 38 oz of muriatic acid. The previous owners left some in our basement, which is now at least 4 years old. There's also some Baquacil (pH decreaser). Are these chemicals still good to use?
    Besides the muriatic acid, what else I should do?
    Thanks!
    27K gallons
    IG, Vinyl
    Sand filter-Haywood S200
    City water
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: What's eating all the chlorine I put in?!
    SLAM TIME!!! Pool School - SLAM - Shock Level And Maintain
    e: The MA might still be good. Throw anything that says baquacil away!!
    Wait, was this formerly a baquacil pool?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by jaadkyki View Post
    FC 0.5
    CC 1
    TA 150
    pH 7.8
    CYA 70
    Borate 0
    CH 300
    Thanks!
    Is 50% drain refill an option? This is to bring your CYA down to make your life easier later.
    If not- add MA to bring pH down to 7.2 and stock up on bleach to perform SLAM, at least 20 gallons at your current CYA level. Make sure your filter/pump in good working order.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Aug 2016
    Asheville, NC
    13
    I don't think it was a Bacquil pool. The three containers are all old and dusty, even as of three years ago.
    What I forgot to mention is that, despite the chemicals being off, the water is still gorgeous and there is no algae growth that I can see.
    Does this make a difference whether I SLAM or not?
    27K gallons
    IG, Vinyl
    City water
    Dec 2014
    Santa Ana, CA
    523
    Are you losing FC overnight or not? If you do you don't have choice and need to go through SLAM to stop that.
    In any event bring your FC to target 8 ppm by putting 2 jugs of bleach in, you're dangerously low on FC.
