Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Newbie! Electrical Questions!
    Tootle76's Avatar
    Aug 2016
    Charlotte, NC
    34
    Hi all,
    We are having our 18' Heritage above ground pool installed soon. We have called an electrician to come out. I am so confused at what have the electrician do and how to keep everyone safe swimming. Do we unplug the pump before getting in? What all do I need to know and do?
    Ashley
    - New (getting installed soon) Heritage 18' Round Above Ground Pool
    Jul 2014
    Hope Mills, NC
    567
    Re: Newbie! Electrical Questions!
    The electrician will keep everyone from getting killed. He will use GFCI outlets or breakers to protect you.
    You will never need to unplug anything.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Aug 2016
    Ottawa, Ontario
    16
    I recently had an above ground pool installed. The electrician installed a copper ground wire around the pool,timer for the pump, gfci at the electrical panel.
    Tootle76's Avatar
    Aug 2016
    Charlotte, NC
    34
    Can we run the pump while in the pool?
    Aug 2016
    Ottawa, Ontario
    16
    Assuming all electrical work is up to code, running the pump would be perfectly acceptable.
    Tootle76's Avatar
    Aug 2016
    Charlotte, NC
    34
    So the pump doesn't run 24/7, it's on a timer?
    Quote Originally Posted by Antonio.d View Post
    Sent from my A0001 using Tapatalk
    Aug 2016
    Ottawa, Ontario
    16
    Yes. On a timer. I personally run it from 5h30am to 17h30. Depending on the electrical rates in your area, you may choose to run during lower rate time.
    Tootle76's Avatar
    Aug 2016
    Charlotte, NC
    34
    I always thought pumps ran 24/7!
    Aug 2016
    Ottawa, Ontario
    16
    Not necessary. However, someone with more experience can chime in an correct me, but I run it 12h a day.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    That's a BOND wire, not a ground....it's there to keep you from getting shocked when you get out of the pool. (if a voltage gradient happens)
    Dolphin E10 Cleaning Robot.
    Aug 2016
    Ottawa, Ontario
    16
    Thanks for the precision! In any case, its connected to my panel.
    Tootle76's Avatar
    Aug 2016
    Charlotte, NC
    34
    Quote Originally Posted by borjis View Post
    Should bonding also be done too?
    Aug 2016
    Ottawa, Ontario
    16
    In my area, it is part of the building code.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Quote Originally Posted by Tootle76 View Post
    I can't remember the requirement for an 18' above ground, but I would for peace of mind.
    Aug 2016
    Ottawa, Ontario
    16
    Tootle76's Avatar
    Aug 2016
    Charlotte, NC
    34
    Thanks!
    May 2012
    Montville NJ
    545
    To answer some of the questions
    Bonding is not the same as grounding. Grounding provides an alternate path to ground for electrical systems in case a short occurs. Bonding equalizes the electrical potential between various conductive elements. When you shuffle your feet across the carpet and touch somone, you get a static electricity shock because you and the person you touch are at different potentials. If you had bonded youself to that person (say by holding hands) before you began to shuffle across the carpet, then you would not get a shock when you touch them with your other hand. Same goes for pools - the water, metal, earth, motor, ladder, and any other metal objects are all connnected together by a bond wire, so you cannot get a "static" shock by standing in the pool and touching the ladder for example. That is a bit simplistic of a description, but the general concept is there. Bonding and grounding are both required by the National Electric Code. Most municipalities use the NEC as their building codes, so a licensed electrician should be following them.
    There is no problem getting into a properly wired pool with the pump running. Public pools are required to be filtered 24/7. Private pools are not. You should run your filter/pump as much as it needs to be. How much that is depends on your pool. The old ruile of thumb used to be to run it enough to change over the water each day. That has changed in the last few years. Many people can get away with running it less. I run my filter 4 hours a day for my 17,000 gal above ground pool. I could acutally back that down even more because my solar cover keeps a lot of debris out of my pool. You will be able to figure out what is right for your pool with trial and error.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Tootle76's Avatar
    Aug 2016
    Charlotte, NC
    34
    Quote Originally Posted by phonedave View Post
    Bonding is not the same as grounding. Grounding provides and alernate path to ground for electrical systems in case a short occurs. Bonding equalizes the electrical potential between various conductive elements. When you shuffle your feet across the carpet and touch somone, you get a static electricity shock because you and the person you touch are at different potentials. If you had bonded youself to that person (say be holding hands) before you began to shuffle across the carpet, then you would not get a shock when you touch them with your other hand. Same goes for pools - the water, metal, earth, motor, ladder, and any other metal objects are all connnected together by a bond wire, so you cannot get a "static" shock by standing in the pool and touching the ladder for example. That is a bit simplistic of a description, but the general concept is there. Bonding and grounding are both required by the National Electric Code. Most municipalities use the NEC as their building codes, so a licensed electrician should be following them.
    -dave
    Thank you Dave!!
    Apr 2013
    Sacramento, CA
    2,769
    Generally a pool with a depth of 42" or less does not require bonding. Diameter or size is otherwise irrelevant. NEC 680.2 and 680.30 et seq. Everything must be GFCI protected. It must be more than 6 feet from a outlet.
    If its more than 42" deep its a permanent pool and it must comply with NEC 680.26. Big boy pool bonding requirements.
    Your electrician needs to review those code sections. He should also review this study guide: https://www.google.com/url?sa=t&rct=...TMg5hU0nEgzinQ
  20. Back To Top    #20
    Tootle76's Avatar
    Aug 2016
    Charlotte, NC
    34
    Quote Originally Posted by gwegan View Post
    Thanks!!
