Results 1 to 12 of 12
Thread: Confused about closing chemicals
    Jun 2015
    Ottawa/Ontario
    340
    Do I need algaecide? What about metal "suppressants"? My PB is recommending all sorts, and I naturally don't trust any of them! Aside from dumping a few jugs of bleach, do I really need all the other stuff?
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Donldson's Avatar
    NW Ohio
    2,896
    Re: Confused about closing chemicals
    Lol, he probably wants you to put a copper based algaecide in and then add a metal sequestrant to protect your pool from the copper he had you put in.
    I personally just bring the pool up to SLAM level overnight before covering and pass on the algaecide. I have opened to a clear pool 5 years running. Some people choose to use a polyquat algaecide for added protection when closing but that is personal preference and situation.
    Sent with Tapatalk on HTC Ten
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    You don't "need" algaecide. I do fine without it, some folks use it ( PolyQuat 60, nothing with metals, etc) as insurance. Beyond that, don't waste your money. Pool School - Closing an In Ground Pool
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I always have to add algaecide, but I only add Polyquat 60 as it doesn't have copper. Other algaecides have copper which can cause staining. I get warm spells during the winter and freezes during the early spring that prevent me from opening too early, so I need the insurance that algaecide provides.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2015
    Ottawa/Ontario
    340
    Quote Originally Posted by kcindc View Post
    This sounds like my situation...somewhat of a freeze/thaw throughout the year...
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    Jun 2015
    Ottawa/Ontario
    340
    Quote Originally Posted by Donldson View Post
    Ha!!! No doubt. Thx for the tip!! Will tell PB to pound dirt.
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    Let's move away from the pool closing conversation... I am not even close to ready for summer to end!!!
    17K Gallon,IG Vinyl,1hp Pentair Challenger,Pentair TA60 Sand Filter, Hayward Colorlogic,Re-lined 06-20-15, TF-100,SpeedStir,Lagunitas and Margaritas. Zappafan Pool Build
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Wow, I'm surprised a closing thread got to post six without this secret of TFP. Shushhhh, it's a secret...
    Close as late as you can and open as early as you can. Your SWG will probably stop working, so you may have to use bleach for a short while, both during the closing season and after opening. You want the water cold when you close, consistently below 60 - even lower if possible. Then in the spring (late winter) open as soon as you are sure you are past any days long hard freezes. The secret, cold water inhibits algae growth. The colder the better.
    People will look at you strange, but close cold/open cold and with a little luck you open to a perfectly clear pool
    Support the site
    Jun 2015
    Ottawa/Ontario
    340
    Quote Originally Posted by Zappafan View Post
    Sorry. I asked now because i pay PB to close the plumbing side of things. That way if anything goes wrong, they have to fix it...anyway, when i book now, I say 10%. They asked if I wanted basic close vs an enhanced close where they add a "closing chemical package", for an additional 100 bucks!! When I asked what chems they add, I may have offended them by suggesting their 100$ extra for chems that cost 20$ is a slight rip off!
    Jun 2015
    Ottawa/Ontario
    340
    Quote Originally Posted by tim5055 View Post
    Makes perfect sense. We booked closing for end of September. Next year I will open myself. But better to pass liability of close to PB for the plumbing side of things.
    Apr 2010
    Central NJ
    227
    I've been doing this the last few years but I'm going to try the algaecide this year and try to close earlier and open later than I have in the past. I got tired of maintaining a pool with no benefits. The closing later and opening earlier sounds good, but the extra time, chlorine and pump run time that it requires with no benefit just makes me want to try the algaecide this time around.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Aug 2016
    Warminster, PA
    34
    tag for later
