Thread: Concerns?
    Oct 2015
    San Diego, Ca.
    646
    Concerns?
    What are the concerns by using pH Down by Clorox vs. Muriatic Acid?
    Thanks
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    JoyfulNoise's Avatar
    May 2015
    13,207
    Re: Concerns?
    Dry acid chemicals like "pHDown" are sodium bisulfate. They work the same to lower pH as muriatic acid does, but they add sulfates to your pool water. Every 1lb of sodium bisulfate per 10,000 gallons of pool water will add about 8ppm sulfates. Sulfates above 300ppm can cause damage to plaster known as "sulfate attack" and sulfates are detrimental to the coatings on SWG cell plates.
    Best to stay away from dry acid chemicals.
    Matt
