Results 1 to 16 of 16
Thread: Need some confirmation and feedback- skeptical of pool store advice7.4
    Jun 2016
    virginia beach virginia
    10
    Hello all, and thanks in advance for your time and consideration.
    Bottom line is that I'm a new pool owner and I think I have an algae problem but the pool store seems to think my water chemistry is just fine.
    It's a 24' 52" round, vinyl liner pool with a sand filter and a SWG.
    I've had my pool about 6 weeks now. All has been well up until this past few days after a heavy rain. Went to the pool store Saturday for a check and they said chemistry was perfect.
    Went out this morning and the water is cloudy with a tinge of green. Went back to the pool store immediately and got these readings (luckily I am off today). The clerk seemed unconcerned and had no recommendations:
    Alkalinity: 106
    pH: 7.4
    Calcium Hardness: 352
    Total Chlorine: 0.14
    Free Chlorine: 0.10
    Chlorine Stabilizer: 33
    Salt: 3400
    I reiterated that the water was cloudy and seemed to have a tint of green, and she handed me a 1 pound bag of shock, which I added immediately this morning.
    However, as I reviewed the sheet they handed me with my water chemistry, and the numbers above seem out of tolerance for even their recommendations- on chlorine alone they recommend a max of 3ppm total chlorine and .6-1.5 ppm free chlorine. I'm actually wondering if she doesn't understand that 0.13 is LESS THAN 0.6...
    Now that I have read a bit on the forum, it seems to me that I have an algae problem and need to do something more.
    24' Round 52" Martinique AGP
    Intex ECO 8110 SWG
    Blue Wave Sandman Filter System
    1HP pump
    May 2015
    Land O Lakes, FL
    527
    Re: Need some confirmation and feedback- skeptical of pool store advice7.4
    Pool store is wrong.. . Start reading Pool School and order a test kit. . See tftestkits.net for the recommended kits.
    Read up on SLAM in Pool School since that will be your next step once you get your kit.
    In the mean time, add 1 gallon of bleach each day until the kit comes
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    From your description, yes you do. You need to order a test kit and cut the cord with the pool store. As you have seen, they don't care about your pool.
    I recomend a TF-100 from tftestkits.net. They ship from Raleigh and if you order now they may get it out to you today.
    Until the kit comes in I would add one bottle (121oz, 8.25%) generic bleach to the pool with the pump,running each day. I use WalMart GreatValu, but you can get bleach almost anywhere. No ezpour, scents or flavors of bleach. Plain generic bleach.
    While you wait, do a little reading -
    ABCs of Pool Water Chemistry
    SLAM
    Overnight Chlorine Loss Test
    FC/CYA Chart
    Accurate testing and the information in our guides,is what our system is based on.
    Support the site
    Jun 2016
    10
    Thanks- Added the bleach and am looking at test kits. appreciate the quick turnaround!
    Question 2: I am going on vacation in 2 days. What should I do when I'm gone?
    Intex ECO 8110 SWG
    1HP pump
    May 2015
    Land O Lakes, FL
    527
    How long are you going to be gone?
    Matt
    Jun 2016
    10
    4 days...
    Intex ECO 8110 SWG
    1HP pump
    May 2015
    Land O Lakes, FL
    527
    Since the pool already has algae, the only thing that will solve it will be a SLAM and you don't have time to complete that before your vacation and don't have a test kit to do it.
    Just keep adding a gallon a day and right before you go, I would probably add 3 gallons and keep the pump running while you are gone. When you return, you can do a full SLAM.
    Matt
    Jun 2016
    10
    Great, thanks!
    Intex ECO 8110 SWG
    1HP pump
    Aug 2014
    Northern IL
    4,615
    Order the testkit now so it will arrive as soon as you come back from vacation. You won't regret it if you stick with us!
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by MarianParoo View Post
    And if you can swing it, the speedstir is a very worthwhile accessory! .
    Matt
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,635
    You are SO lucky you found us when you did............."oh green in your pool is just fine. Add this bag and it will be all good" NOPE!
    Do as the above told you. When you get home do all of the tests and post them here like this:
    FC
    CC
    PH
    TA
    CH
    CYA
    There are videos for each test on the site you bought the kit from. We also have some tips we can share if you have a problem with a test. There is also "extended testing" directions on the left side of the home page.
    I am going to share a set of links I put together for new pool owners. It is a LOT of info. but it will all fall in to place as you start using the it. This will be for when you clear the pool with the SLAM:
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    we got ya!
    Jun 2016
    10
    Thanks to everyone. I've complied so far, and although I am by nature an optimist and a glass half full (or I suppose in this case it should be pool-half-empty-of-algae) kind of guy, the green tint seems to have lessened a shade...
    Test kit ordered- i got the TF100 with a few options
    Starting on my homework, which is not the kind of summer read I had in mind, but the Outer Banks await.
    I'll keep everyone posted
    mj
    Intex ECO 8110 SWG
    1HP pump
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,156
    I will ship it out today and you may just get it before you go on vacation
    Jun 2016
    10
    Well, I am back from vacation and the pool looks pretty good (I was a bit nervous after watching the Olympic diving events...). Clear without a hint of green.
    My test kit was waiting for me and I ran my first test a bit ago (I ran the tests twice and got consistent results):
    FC: 2
    CC: 1
    PH: 7.2
    TA: 132
    CH: 375
    CYA: 55
    The 'Low Salt' warning light on the SWG came on, so I added salt as per the manufacturers instructions.
    Intex ECO 8110 SWG
    1HP pump
    Jul 2012
    Tallahassee, FL
    30,635
    Look in my siggy for the SLAM link. You need to do a SLAM to get your cc levels down and to make your pool look like a jewel!
    I am glad it is not worse.
    Look at the links above for where your levels should be after the SLAM.
    Jun 2016
    10
    Wilco
    Intex ECO 8110 SWG
    1HP pump
