Results 1 to 9 of 9
Thread: effects of higher FC and PH testing
    Sep 2015
    Charlotte,NC
    88
    I know that if FC gets too high then the PH numbers will be off. Question is are PH numbers the same at FC levels of 4, 6, 8 (all in range of my CYA of 50) I am seeing some PH bounce around over the last week or so from 7.4 to 7.7-7.8(not quite the color of 7.8 but not 7.6). I didn't record the FC when I did the testing so the FC could be between 4-8 which is where I try to keep it. I know my TA is low but it was recommended here to leave it be unless you are getting PH bounce. I wish there was a drop test for PH like all the other test we do , trying to look at a color is pretty subjective to lighting.
    FC 8.0
    CC 0.0
    OCLT 0.0
    CYA 50
    PH 7.7
    TA 60
    CH 110
    Location Charlotte NC. Pool is a IG vinyl liner, 18X36 lagoon approx. 20,000 gallons odd shaped pool with different depths. 2 skimmers, 3 returns. Hayward 1HP pump, Hayward cartridge filter, Hayward chlorine feeder, Laars 250,000 BTU heater. Stenner pump with #2 tube for chlorine injection. Leslie branded Taylor test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: effects of higher FC and PH testing
    It should have a minimal effect if any at all. As a color match test, the pH is a little subjective. But, don't fall in the trap that your pH needs to be exactly "X". It's better to keep it in a comfortable range, like 7.4 - 7.7 rather then fighting to keep it at exactly 7.5.
    Support the site
    30,432
    Yes.
    JoyfulNoise's Avatar
    May 2015
    13,265
    I don't mean to pile-on as the answers already given are correct; but let me just add to them. With an FC between 0-10ppm, the R-0004 reagent is designed to read correctly as it has a chemical formulation that neutralizes the chlorine in a way that doesn't change the pH. Between 10-20ppm FC, the formulation can't neutralize all of the chlorine in solution BUT the reaction of chlorine with phenol red is slow enough that even in that range you probably have 30sec or so before the color starts to change (chlorine causes the phenol red to turn into chlorphenol red which has a reddish-purple color at pH above 7.0). Above 20ppm FC, the reaction starts to happen too quickly to get an accurate reading and, above 25ppm, the phenol red will be completely compromised by the chlorine present.
    So your pH fluctuations are due to something else in your testing, not your FC levels.
    Matt
    Susiejax's Avatar
    May 2016
    Fort Wayne, Indiana
    50
    Thanks for this helpful info! I have to keep my FC pretty high because I am operating a high-CYA pool at the moment. Good to know exactly what is happening with the Phenol Red.
    22,400 gal; in-ground gunite rectangle, vinyl liner; 3.5'-8' depth; Chlorine; auto cover; Hayward Pump and Sand Filter; Hayward Electric Heatpro; diving board; 3 sidewall fountains; open mid May thru mid October; built 2011; Taylor K-2006C FAS-DPD Test Kit
    Nov 2015
    Ok ok
    824
    JoyfulNoise: with C less than 10, do you still have a ~30 second time frame to read the ph? Just curious as sometimes I do the test and look to confirm again after I complete other tests.
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    May 2014
    Franklin, NC
    9,216
    Quote Originally Posted by Lykly View Post
    No, you have more than 30sec below 10FC. As Matt pointed out, the Taylor,solution contains a chlorine neutralizer good up to 10FC.
    Support the site
    May 2015
    13,265
    There should be no waiting or letting test samples sit around. Just simply take your reading as soon as the sample is properly mixed and discard the solution once you're done. Any solution left to sit around would be considered invalid in my opinion. I test pH daily (or pretty close to that). The way I do it is too add my 5 drops of phenol red, invert twice or three times (gently!) to mix and then read the color. I usually stand in the shade under an awning but I put my hand holding the test vial out into the bright light. I then point the tube at one of my chase lounge chairs (which is bright white) and I read the color. It's very accurate that way and I always get the colors that I expect.
    Matt
    Nov 2015
    Ok ok
    824
    Much the same way I do it, I usually stand in the shade and use a light colored background, normally a light colored cloud if available. You can normally tell when you have the background correct because all the colors make sense. Thanks for answering my question, even though I normally read it right away, I will sometime set it down while I perform other tests and then look at it again to see if the result has changed. I do understand though, that the initial test result is the valid one.
