Results 1 to 7 of 7
Thread: Just got my test kit, now what do I do? new pool owner...
    Aug 2016
    syracuse NY
    39
    Ok I had some issues with stabilizer so my TC kit came Saturday evening, I tested the water yesterday-
    FC 5
    CC 1.5
    Calcium Hardiness 300PPM
    TA 110
    CYA 30
    I added stabilizer (2 lbs) on July 29th waited three days then checked it and it was still low. I added another 1 lb. on Sunday July 31st
    Then checked it Aug 3rd, still low and added another 1 pound.
    Seems like my PH is high now too?
    AG, SWG, OPERA series, 15 x 26, pool pilot digital nano plus/220V, cartridge filter, May 2016 install.
    Jun 2014
    15,059
    Re: Just got my test kit, now what do I do? new pool owner...
    Sue, I don't see your pH, but before you increase CYA any further, perhaps we should make sure your water is clear and algae-free first. While you should have a minimum CYA of 70 for a SWG pool, if you have any cloudiness or hint of green algae somewhere then you'll want to do a "SLAM" at a lower CYA level to save on bleach. Your CC is a bit elevated which is a sign that your pool is trying to get rid of some excessive organics. Before you go too much further, you might want to perform an overnight (OCLT) test to rule-out algae or the need to "SLAM". If you pass the OCLT, then continue to adjust CYA to 70.
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    You can post your pH on the next update.
    Aug 2016
    syracuse NY
    39
    Hmmm in the kit it said the TA test determined PH and for SWG it should be between 60-80? Maybe I skipped something, I will have to go back and check again.
    The pool is crystal clear, no algae at all.
    I will check out the OCLT-thanks
    Aug 2016
    syracuse NY
    39
    With SLAMming the pool, if I need to do that, I add bleach or chlorine? Even though it is a SWG? There is a BOOST button on the nano-cell which I was told to do about once a month, I am guessing that si not the same as SLAMming the pool?
    Jun 2014
    15,059
    Bleach and chlorine are the same thing. So you can go to your local grocery store and use whatever bleach is the best bargain - generic is fine. Just nothing that says splashless or scented - only regular. Generally bleach is the best choice for a SLAM because SWGs are not designed to sustain such high FC levels over a long period of time - especially in the early part of the SLAM when FC levels might drop fairly quickly. Just give the SWG (cells) a break. But you can experiment and try. The SWG may be helpful if you leave the house all day and are not around to manually add bleach.
    Aug 2016
    syracuse NY
    39
    Did the OCLT test, FC was 5 last night and 5 this morning. So I added more stabilizer, about 1 1/2 pounds. I also checked the PH, it is 7.8. I think that is a little high? I'll check the stabilizer again in 3-4 days and see if it went up at all.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    A passed OCLT, woo hoo. 7.8 is perfect - just keep an eye on it as it will tend to rise with a SWG. Lots of pools settle out around 7.8 so hopefully your's is one of those. If it creeps up, add some muriatic acid and knock it down to ~7.5. PH/TA will likely be your main focus as your FC should be kept pretty level by slight adjustments of the %.
    Good plan with the CYA. In the mean time, enjoy that pool!
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
