Results 1 to 11 of 11
Thread: chlorine dropping rapidly
    Jun 2016
    Carmichael, CA
    4
    Hey there,
    We get the chlorine to the right balance, then within 3 days the level is back to near zero. We got a floating tablet in there now. run the pimp at 2k from 10-5 then 3400 with the vacuum from 7-9pm. stumped on whats going on. It doesnt seem normal to have to add this much chlorine. PH is usually good, and doesnt fluctuate quickly. Any help would be great, thank you.
    15000 gal, in-ground, Gunite Material, Pentair 011018 Pump, Polaris PB460 tertiary pump for skimmer
    Jun 2015
    Glendale, AZ
    156
    Re: chlorine dropping rapidly
    You need to add chlorine daily.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Jun 2016
    Carmichael, CA
    4
    None of our neighbors add daily. I just read up a bit. we are not adding any CYA. I think that might be the problem.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    You are adding CYA with the floating tablet. You really should be adding chlorine everyday.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    Jun 2016
    Carmichael, CA
    4
    So how do pool services have good water only visiting every week? Some thing seems off. So I have to add chlorine daily, then when can I swim in the pool if Im always adding chems.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    You can swim daily - even when adding chemicals. Pool services don't have pristine water. If you follow the TFP way you don't need/want pool service.
    VinDeeLoo
    Aug 2014
    Northern IL
    4,615
    Maybe reading this will help you understand what we do:
    Pool School - What is TFPC?
    Jun 2010
    Glendale, CA
    513
    As others have mentioned - more reading in pool school is required to wrap your head around the process.
    To answer your Pool Service question more specifically :
    Pool services tend to elevate the chlorine level to "shock" the pool each week and then leave a Tabs in a floater or chlorinator to maintain the rest of the week. In order to compensate for not properly chlorinating the pool they also tend to add phosphate removers and algecide to help keep algae from growing.
    Overtime levels of CYA, Copper and/or calcium build up to the point where the pool has constant "issues" - so you drain the pool and start over.
    The things you'll learn here are a more science based approach to pool care management.
    Regardless - "Chlorine" (Hypochlorous Acid) is used up everyday and must be replenished from some source.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by Crystal Clear Trumbo View Post
    Hey there,
    how did you get those numbers? We strongly advocate for pool care which starts from reliable and accurate testing. It's impossible to make recommendations if you don't know exact levels of the chemicals in the water.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    Here is a set of links I share to help pool owners understand the whys and hows of TFP:
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Here TFTestkits.net is a good place to get a recommended test kit.
