Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: New Pool owner, not sure what to do next...
    Aug 2016
    Massachusetts
    15
    Question New Pool owner, not sure what to do next...
    Hello all,
    Looking for some help. I'm a first time and new pool owner. We bought a house, and with it came an above ground pool (full details in my signature).
    Last weekend my father-in-law and I went to Leslie's (literally round the corner) and had the water tested to see where we were at. It was at that point we were told that the town I live in has high amounts of copper in the water. The manager said that we need to put in a 1 liter container Natural Chemistry Metal Free, run the filter for 24 hours and then come back.
    The following day, we went back and had the water retested. This was the results:
    Free Available Chlorine (FAC) = 0
    Total Available Chlorine (TAC) = 0
    Calcium Hardness (CH) = 700
    Total Alkalinity (TA) = 30
    Base Demand = 8
    Copper = 0
    Iron = 0
    Total Dissolved Solids = 1100
    We were told it was OK to swim in that night (our twin girls were chomping at the bit to swim), so we did, after I spent the afternoon scrubbing the pool to clean off the slight amount of algae that was in there. We knew we'd handle the high calcium afterwards. My Father-in-law wanted to show me how to backwash the filter (he's had pools all his life) and basic maintenance. He has a pool service, so doesn't worry about the testing, cleaning etc.
    Leslie's advice was to train the pool a foot, and refill to reduce the amount of calcium. So, the Father-in-law showed me the pump, filter etc. It's in a kind of awkward place under our deck. It's in a such bad position, that we had to take a picture of the top of the sand filter to figure out where the various settings were (filter, rinse, waste etc.). The lack of access and view led to my Father-in-law incorrectly setting the handle to waste instead of backwash. It was set to 'waste' to drain the pool. We drained the pool as much as we could, but as soon as the level dropped, the skimmer wasn't able to pump the water out. I think in total we dropped the level about 6 inches maybe, if that.
    So then we set about filling it up with more water. This is the point where pretty much all **** has broken loose.
    Ever since last weekend, the pool has steadily looked worse. There is a definite green tinge to it, and the algae is back with a vengeance on the stairs and sides. There also a definite cloudiness to it too. My 4 year old girls even asked why the pool is green now, so it's pretty obvious. In my very basic understanding, it would appear from the test results that there's no chlorine to kill/stop the algae from forming.
    So yesterday, I took another sample to Leslie's. Here were the results:
    Calcium Hardness (CH) = 130
    Cyanuric Acid (CYA) = 50
    Base Demand = 8
    Copper = 4
    Iron = 0
    Total Dissolved Solids = 1700
    Phosphates (Pho) = 300
    The advice from Leslie's is that we have to get the copper removed before we can handle anything else. So this time around, I was told to buy and put in 2x 1 liter container Natural Chemistry Metal Free in. At this point, I'd figured out the timer, and the filter was only running 8am to 8pm all week (including after putting in the Metal Free).
    I went back today, had the water tested (didn't get the results), and was told copper was still high. She asked about the filter, and I told her it was only running 8am - 8pm. Her advice was put in another Metal Free and run the filter for 24 hours. I put in the Metal Free and disabled the timer, so the filter will run constantly for 24 hours. That was this afternoon. I again looked at the pump and filter. I noticed the pump had a significant amount of debris in the basket. Dead insects, leaves and whatnot. I opened the pump up and cleaned out all the debris. Later on, I noticed the basket in the skimmer wasn't sitting correctly, so I guess a fair amount of stuff had got through to the pump. Then I looked at the filter and noticed the where the backwash setting was, as opposed to the waste setting we used the previous week. So, I did a backwash, and the water came out and I could tell it was green. So, I ran it until it was clear, did a rinse, and turned the filter back on,
    So, this evening, I ordered the K-2006 test kit. I want to understand and have less of a dependence on Leslies (even though they've been really helpful) and test as frequently as I can/should.
    I'm asking for advice. I'm at the mercy of Leslie's, and so far the pool has gone from being swimmable to looking pretty grim, so I'm a little skeptical right now. I'm reading the getting started guides and trying to understand the chemistry, but I can't really do much until my kit arrives, other than keep going to Leslies.
    What should my next step be?
    Pool size: 9,400 gallons, AG, vinyl
    Pooline, unknown model sand filter
    Accuflow 02-ACC-72730 pump
    TAYLOR TECHNOLOGIES INC K-2006 TEST KIT COMP CHLORINE FAS-DPD
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: New Pool owner, not sure what to do next...
    Welcome to TFP!
    I guess my first question is - how are you or are you adding chlorine to the pool? Your first test showed no chlorine. Did they not tell you to add some? Did you add any?
    You have ordered a good test kit, great! But, you need to learn some water,chemistry before it arrives.
    ABCs of Pool Water Chemistry
    SLAM
    Support the site
    Aug 2016
    Massachusetts
    15
    Thanks for replying! Yeah, the first AND second test showed no chlorine. I bought a bucket of the chlorine pucks for the floating chlorinator after the first test, but it's clearly not increased the level at all. This has been somewhat of a mystery to me. I understand the need to remove the copper, but having zero chlorine and not suggesting to increase it seems a little odd. In fact, they recommended not to, for reasons I can't remember. All the times I've been to Leslie's, they've said to do nothing but remove the copper, due to the effect it's having on the other readings.
    It's my assumption i'd need to do a SLAM to a) kill algae and b) raise the chlorine levels, but as a brand new pool owner, up until now, I don't have the experience or knowledge to second guess my local pool store.
    May 2014
    Franklin, NC
    9,184
    Please,understand, the local"pool store,is in business to move money from your pocket to their cash register. I trust a new pool owner armed with the knowledge in Pool School and a test kit over a dozen pool store "experts"
    Support the site
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by Kenny_Login View Post
    I personally don't understand pool store testing results for copper when it suddenly jumped from 0 to 4 between 2 tests they did. The only thing which was done in between was draining 6" of the pool and refilling it with city water. Even if average depth is 4' = 48" it means city water had copper content at 4 x 8 = 32 Is it even possible?
    Kenny_Login: is it possible to find copper content in your city water buy any chance? In the worst case can you bring sample of your tap water to Leslie's to test for copper? Just trying to understand what to expect when chlorine is added.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    I am jumping ahead a little but I wanted to share this set of links I set up for new pool owners. It is a lot of info. so take it a bite at a time. I hope these will help you understand how and why we do things here at TFP:
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    Aug 2016
    Massachusetts
    15
    Quote Originally Posted by max2k View Post
    Here's the town's water report:
    My copper testing kit will arrive tomorrow, so I'll test it myself tomorrow after having put in the Metal Free and ran the filter for 24+ hours.
    Aug 2016
    Massachusetts
    15
    Quote Originally Posted by kimkats View Post
    Print these out:
    Bookmark these:
    Thank you! Still working my way through all the handy guides and information.
    Aug 2016
    Massachusetts
    15
    Quote Originally Posted by tim5055 View Post
    I'm waiting on my test kit for copper and the K-2006 test kit. I'm going to buy a bunch of bleach today for the purpose of SLAMing the pool. My question would be, do I ignore Leslie's advive and/or the copper readings and work on SLAMing the pool to kill/control the algae? Then once that is taken care of, then work on bringing down the copper levels? The other test results seem that they need a few tweaks, but aren't wildly out of whack like the chlorine and/or copper.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, slam first and work the copper afterwards.
    Dec 2014
    Santa Ana, CA
    523
    if I understand this correctly you most likely with probability of 90% have copper level of 0.04 ppm or less. I think it can hardly be considered as 'high' copper water so at least you'll have an option to refill the pool with that water. I'm not saying you'll have to, just an option.
    Aug 2016
    Massachusetts
    15
    So, I'm in the process of shocking the pool, and I took a CYA reading and it jumped from 40 (pre-shock) to 55. I used the Pool math to recalculate the amount of chlorine based off this new number, just to be on the safe side. Is this normal?
    Dec 2014
    Santa Ana, CA
    523
    CYA does not jump on its own. What did you use to 'shock' the pool?
    Please note SLAM is not one time event but rather process where you bring FC to the 'shock' level corresponding to your current CYA and keep it there until you pass OCLT. You bring up FC using liquid chlorine (bleach) and nothing else. Your current SLAM FC level based on CYA=55 should be 24ppm and you should check it regularly, every 2 hrs at the beginning as it will drop due to algae killing process so you'd need to bring it back to 24 ppm. It gets easier as time passes. Please run your pump 24/7 and brush the pool as often as you can.
    Aug 2016
    Massachusetts
    15
    I bought 12 gallons of the Home Depot 8.25% bleach. I've been keeping the FC at whatever level Pool Math has been telling me since Thursday and brushing every day. I'm testing every ~4hrs with my K-2006 test kit. I may have misread the CYA, but I've been keeping the level on the high side (currently it's at around 20.5 ppm). Is the CYA test reliable during a SLAM, given that the process adds murkiness to the water, and the CYA test is looking at a black dot through already cloudy water?
    Dec 2014
    Santa Ana, CA
    523
    You need to check CYA once (or few times to make sure) at the beginning of SLAM to determine your target FC level using FC/CYA chart. CYA is not changing on its own if you're using bleach only for chlorinating so there's no point in checking CYA often as you'd be getting the same results. FC is the only parameter you need to monitor during SLAM.
    Aug 2016
    Massachusetts
    15
    Ok, cool. Just finished brushing the pool, and decided I would unbolt the steps and remove them. When we first inherited the pool, that was the hot-spot for algae. The back of the steps were pretty green. I'm glad I did. Although it's not bad, there's definitely pockets of algae still clinging on for dear life, so I'll be scrubbing the steps pretty thoroughly too.
    Dec 2014
    Santa Ana, CA
    523
    Sent from my Nexus 6P using Tapatalk
    I think you got it- good luck with SLAM! Please keep close eye on your FC level. It tends to drop fast at the beginning of SLAM and you need to keep bringing it back with bleach.
    Don't hesitate to ask any questions, this forum has a lot of very helpful members.
    Aug 2016
    Massachusetts
    15
    Thanks for your help. Hopefully I'm pretty close. FC dropped by 1.5 overnight, and CC is at 0.5. The water is still cloudy, but I know that will take running the filter 24/7. Fingers crossed!
    Jul 2012
    Tallahassee, FL
    30,525
    Max has you well covered!
    How about taking and sharing a picture of your pool. If you take one a day you can watch it change color and clear up. Your eyes will not be able to see it day to day. The pictures help you keep your sanity during the SLAM.
  20. Back To Top    #20
    Aug 2016
    Massachusetts
    15
    Just wanted to share some pics of the pool. Here it is 2 weeks ago, just after we moved in:
    Then 1 week ago:
