Results 1 to 10 of 10
Thread: Wire diagram for sand filter pump
    Aug 2016
    LaGrange
    6
    Does anyone have a wire schematic for an intex sand
    filter pump motor ?
    22,551
    Re: Wire diagram for sand filter pump
    I don't think I've ever seen a wiring diagram for one of those motors?
    Is there any kind of data plate on the side of the motor itself?
    Aug 2016
    LaGrange
    6
    Not really it has 3 wires for the plug then a green wire a white wire and a black wire from the armature then a circuit board that has 4 connections
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Today I change the board , using my old pump, let me add some pictures..
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I just unscrew the wires that were going down to the motor, the yellow on the right, the black that was connected to the switch, the black that was connected to the top board, the ground green wire and the white that connects to the left side, then I removed the the four screw at the bottom of the housing and swap the whole body, hope you understand, can I ask what is your purpose?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I did it, bc the switch was faulty, and was stopping before the time set in the timer
    Aug 2016
    LaGrange
    6
    Thanks buddy you are a blessing. .I replaced the bearings that were worn and forgot to take any pictures of how the wires were placed , but with those pictures you posted I should be able to go by that and put the wires in the correct spot ..a new motor is 140.00 and bearings were $8 saved me some money thank you so much
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Let us know, how it works...
    Aug 2016
    LaGrange
    6
    It worked now my next problem is I got it all wired and put back together tested it and it's running , but when I hooked it up to my sand filter and started flowing water through it , water is leaking from the bottom of motor housing? Can't figure what the problem is , if you know would you help ?
