Thread: Mustard algae??
    May 2014
    Muncie, Indiana
    30
    Mustard algae??
    So for the last few weeks I've noticed rust looking debris on the bottom of pool sporadically throughout. Not sure if it algae as the water is clear. Brushes up easily but in a few days it's back again. I back washed today and there was a lot of greenish water in the glass piece. We have had in unseasonable hot summer. And I noticed chlorine dropping significantly after a day or two of adding liquid chlorine. I've tried to find the amount I need to slam the pool but can't seem to find it on the forum. I'm just nervous to slam because I already have some wrinkles in liner and really don't want to add to it. My test results are:
    Fc: 13
    Ph7.4
    Cc: .5
    Tc: 13.5
    Calcium: 250
    Ta: 130
    Cya:60
    Any help?
    12k gallon inground pool with vinyl liner. Sandfilter, hayward 1.5 hp pool pump. Pool is approx 15 yrs.old. Liner is four years old. TF100 testing kit.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Mustard algae??
    no need to worry about the SLAM, it will not hurt your liner
    the page you're looking for is in my sig below also here Pool School - Chlorine / CYA Chart.. Your SLAM FC will be 24 for CYA of 60
    I do not think it is mustard algae, you may have some metal in the pool or it may just be the beginning of an algae breakout.. could you post a pic so we can see what's going on
    I hope this helps
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Mustard algae??
