Thread: Skimmer gaskets for IG vinyl liner replacement
    Aug 2016
    Louisville, KY
    1
    I'm getting the vinyl liner professionally replaced on my in ground pool. It has one Hayward SP1085 skimmer and two Aqua Genies. It appears that all of these have gaskets on both sides of the pool wall.
    Do I only need to buy new gaskets that go between the vinyl liner and face plates? Or, are they able to somehow replace the gaskets between the pool wall and the skimmer body? Thanks for the help!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Skimmer gaskets for IG vinyl liner replacement
    Welcome to TFP
    I would replace all the gaskets but I do not think they can replace the one behind the wall..
