Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Algae aftermath
    Aug 2016
    Fulton/MD
    11
    Algae aftermath
    Hello all. I am a pool noob but I am eager to learn. Opened my new house's pool up in July and everything went great for a month. Then I had a cloudy issue which quickly turned into a green issue. I've been going to my local pool store (dramatic pause for everyone to laugh at me) and they gave me the magic algecide chemical. That was 5 days ago. It worked great at removing the green within a day. But for the past 4 days I am left with a milk cloudy mess. So far I have tried the clarifier, extra chlorine, and I have the pump running 24/7, all while back washing almost every day. Today I did my first vacuuming, which was exciting (did I mention I am huge nerd) but seemed to leave the pool even more cloudy!
    I know you want test results, but I just now discoverd this site and as a result ordered a Taylor 2006 test kit so the chemical composition may be a few days out. All know at the moment is what the generic strips say, which is chlorine is high, and ph is a little low. I appreciate anyone that would like to steer me in the right direction.
    30k in-ground * 1hp pump* Sand filter * Plaster lining * Well water * Diving board
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Algae aftermath
    Add a gallon of bleach with the pump running each day until your test kit arrives. Post results and we can go from there
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Re: Algae aftermath
    Welcome to TFP
    You'll be ok. Read up on the links below and ask questions as you have them you will find no shortage of help here.
    Pool School - SLAM - Shock Level And Maintain
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: Algae aftermath
    Well the two above me have it all covered so all I have to say is HI! You are going to love TFP! Your wallet will love it as well!
    Aug 2014
    Northern IL
    4,615
    Re: Algae aftermath
    How low is "low" with the pH? It's the one test that strips and pool stores usually get right as it is a pretty simple test.
    Aug 2016
    Fulton/MD
    11
    Re: Algae aftermath
    Wow thanks for the welcome guys. Didn't expect such responses so quickly!
    The strip colors look like they come out darker then the 6.2, but not as dark as 6.8.
    Also, add a gallon of bleach? As in head out to my local grocery store and get a gallon of Clorox bleach we use for laundry?
    Dec 2014
    Santa Ana, CA
    523
    Re: Algae aftermath
    Quote Originally Posted by piespa View Post
    Welcome!
    It's hard to believe but- yes, plain unscented non splashless bleach . Your algae is just regrouping for the final attack to turn it to swamp with frogs. It always muddies the waters first . 1 gal/day will keep you somewhat hanging until you can post actual test results.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Aug 2016
    Fulton/MD
    11
    Re: Algae aftermath
    Holy cow. Ok. Liquid bleach for now, stay tuned for test results. Thanks again guys.
    Secondary note, my novice research has told me the algae should be dead, and their carcuses are what is making the water white. Which I thought the vacuuming would clean it out. Is this not the case? Did those green jerks actually survive my $90 murder sauce I purchased and dumped in the deep end??
    Dec 2014
    Santa Ana, CA
    523
    Re: Algae aftermath
    If it helps at the end when you get your water clear and sparkly you'll be adding about half of that every 2 days in hot weather to maintain chlorine level, much less at lower temperature. Besides that there could be some other smaller additions from time to time but chlorine is the cornerstone of TFPC. No other expensive potions are required. When maintained at correct level chlorine doesn't smell, doesn't cause irritation and kills every living thing in there (except swimmers) much faster than anything else. I particularly love it for simplicity and low maintenance nature.
    Nobody can tell if algae survived or not- we saw many cases here when it proceeded to swamp few days later. Ppl would go to the store, buy another round of products, dump in the water just to observe another temporary improvement creating unimaginable mix of chemicals out of their water. Since you're on well water so I'd be careful with that. In the worst case bleach 'disappears' from the water on its own within days so nothing would be lost if you change your mind later. No one ever done this but there's always first time for everything .
    If you could reliably test FC level you'd know for sure but currently your guess is as good as anyone else.
    Aug 2014
    Northern IL
    4,615
    Re: Algae aftermath
    Do you have any water features? A slide? Fountains? Waterfall? If so, you can turn them on and it will aerate the water and help raise your pH.
    Jun 2010
    Glendale, CA
    513
    Re: Algae aftermath
    You should expect that some of the algae survived and if you don't keep the pool properly chlorinated they will grow back.
    Bleach - There are a bunch of "chlorine" products out there. It's really important to understand that from a sanitation point of view it's all the same thing. Bleach, chlorinating liquid, chlorine pucks, bags of shock - it all contains hypochlorous acid - and that is what keeps your drinking water safe (and your pool clean).
    We recommend using liquid forms of chlorine (bleach) because they do not contain unwanted additional chemicals. All solid forms of chlorine have additional chemicals that build up in the pool water over time and cause problems
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Aug 2016
    Fulton/MD
    11
    Re: Algae aftermath
    Hello again. Here is the update, I have been back washing the filter and pouring a gallon of bleach in the pool daily. The cloudiness has actually subsided. I can now see the bottom of the shallow end clearly and faintly see the bottom of the deep. When I first posted I couldn't see the bottom at all. Test results are as follows:
    FC 18ppm
    CC 1.5ppm
    8 drops to raise the ph to an acceptable level (the book says that correspond to about 6lb soda ash for my sized pool?)
    180ppm alkalinity
    160ppm calcium hardness
    70ppm cya
    Last edited by piespa; 08-10-2016 at 07:58 PM. Reason: Retested the CYA, misread the instructions the first time
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    455
    Re: Algae aftermath
    Don't worry about your PH until you are finished with the SLAM...
    PH tests are NOT reliable with a FC of 10 or higher.
    Nice to see that it is starting to clear up for you.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Dec 2014
    Santa Ana, CA
    523
    Re: Algae aftermath
    FC 18ppm
    CC 1.5ppm
    180ppm alkalinity
    70ppm cya
    yes, just focus on FC & CC until you finish SLAM, no need to conduct other tests while in SLAM.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Re: Algae aftermath
    FC 18ppm
    CC 1.5ppm
    180ppm alkalinity
    70ppm cya
    Are these numbers from your new Taylor test kit?
    If so, keep in mind you were battling algae and you want to follow SLAM process (link in post #3). That means keeping your FC at shock level for your CYA until you pass the three tests. Clear water. CC of less than .5 and overnight chlorine loss of less than 1
    18fc is not high enough for a CYA of 70. You should be maintaining 28 FC. Pool School - Chlorine / CYA Chart
    Of course if you just got your test kit you wouldn't have known where you were.
    Aug 2016
    Fulton/MD
    11
    Re: Algae aftermath
    Yes these are the first numbers from the Taylor test kit. I was about 24 hours removed from my previous gallon of bleach, wanted to test the pool as-is first. Just now added my daily gallon of bleach. I will test again in the am and am guessing will need to add more in the morning. Seems like it's going in the right direction though. I really thank you all for the responses and advice.
    Aug 2014
    Northern IL
    4,615
    Re: Algae aftermath
    Do you know how to use PoolMath? Here is a tutorial:
    Forget the booklet and use PoolMath instead.
    I am concerned about your low pH. PH tends to read HIGH, not low, at elevated FC levels. What was your reading?
    Aug 2016
    Fulton/MD
    11
    Re: Algae aftermath
    Thanks for the pool math link. Haven't seen that one yet.
    The reading was outside the range of the test kit, which measured for ideal ranges. The instructions said to count the drops needed to get into ideal range, which I did. Didn't give me a ph number but their magic book instead gave a recommendation.
    Aug 2014
    Northern IL
    4,615
    Re: Algae aftermath
    Do you have a slide, fountains, and/or a waterfall? If so, turn them on to aerate the water. If you can get some 20 Mule Team borax, you could add a box of that. Mix it in a bucket of pool water first.
  20. Back To Top    #20
    Aug 2016
    Fulton/MD
    11
    Re: Algae aftermath
    No slides fountain or waterfalls. I will pick up some of that borax today. This morning the FC was at 24ppm and CC was still at 1.5ppm. I added the bleach last night so that clearly bumped up the FC.
    Pool cloudiness continues to recede slowly into the deep end. I do however see some little grayish smoke clouds on the bottom in some places. I assume that is dead algae? Should I sweep that up? Vacuum it? Or leave as is?
