Results 1 to 8 of 8
Thread: 24 Ft AGP Circulation Issue
    Jun 2015
    Round Rock, TX
    41
    I hard plumbed my intex ultra frame with a through wall skimmer and two returns (I have a second port for vac that I have not plumbed to the pump yet). The 1/2 hp 2100 GPH pump is not taking care of circulation well. I have a dead zone that collects dirt, grass and leaves that becomes an ignition point for algea if I don't get the bot in the pool every 2-3 days. SWG runtime in this Texas sun is 12h/per day right now, 8h for the shoulder months. Time to upgrade!
    Before you ask, I have done the standard eyeballs angled down (4 o'clock), 3/4 pipe with dual 45 degree elbows, pointing one down at 45 degree and underwater by 12 inches, the other just down at 45 degrees.
    I read the thread by jeffchap (link) with interest but the Pro is a 1hp single speed, no timer so I'll need to wire one up (or home automation socket?).
    We are considering a sunk in abg in a year or two when this Intex fails, likely nearly the same size. I know at that time, I would want a two speed pump for power savings, skimming more often, etc.
    Doing the $200 marginal upgrade with just a timer added to it would buy some time. A two speed would likely need my power wired in, timer system, and perhaps new SWG.
    Thought I would ask for opinions and any threads that apply.
    Thanks
    Intex Ultraframe, 24' x 52", 1.5hp Matrix 2 speed, 21" Hayward sand filter + Intex Ozone Saltwater System, through-wall skimmer, 1.5" PVC return fountain. Taylor K-2006 & K-1766 test kits.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: 24 Ft AGP Circulation Issue
    If you're going to a permanent setup it would be better to get a complete setup with power and a shutoff/breaker at the pump but I also understand doing things a little at a time
    here are a couple recommendations
    pump: I love my 1hp pentair, on low 90% of the time and uses very little power and when you need extra power to vacuum or clean its there on high... and the price is great..
    Amazon.com : Pentair 340042 SuperFlo High Performance Energy Efficient Two Speed Pool Pump, 1 Horsepower, 230 Volt, 1 Phase - Energy Star Certified : Swimming Pool Water Pumps : Patio, Lawn Garden
    this one is 3/4 HP 2 speed and plugs in
    Amazon.com : Energy Efficient 2 Speed Pump for In-Ground Swimming Pool 0.75 HP-115V : Patio, Lawn Garden
    Jun 2015
    Round Rock, TX
    41
    [QUOTE=cowboycasey;1114048]
    I had looked at both of those, neither has an timer to switch speeds. As I look more at options, it would be nice to put the Aquacritter in the pool plugged into a port while I'm not in town and have the pump run on low for a set time period daily for SWG generation, then switch to high for an hour and get the bot zipping around to cover the bottom.
    Vois La! Full TFP! Pool Zen!
    Possible with less than four significant digits on the pricetag?
    Thanks
    Jul 2013
    Fletcher, OK
    3,353
    here ya go it will not switch speeds but it will turn it on.. just leave it on low if your gone and then if your at home you can switch it to high for an hour or so
    Intermatic P1121 Heavy Duty Outdoor Timer 15 Amp/1 HP - Plug In Timer Switches - Amazon.com
    Jun 2015
    Round Rock, TX
    41
    I found this on Amazon, 1.5 HP Pump, 23 inch sand filter https://amzn.com/B002EL40P4
    This timer can be added https://amzn.com/B003LSBWAU
    Not fully programmable, but it will allow dual speed operation in 6 hour chunks.
    Jun 2015
    Round Rock, TX
    41
    Quote Originally Posted by Hmelton View Post
    That one was a single speed, d'oh! Ordered a dual with 21" sand filter setup that should get me to zen again. https://amzn.com/B002HHM020
    Jul 2013
    Fletcher, OK
    3,353
    nice combo, a little big at 1.5 hp but a 2 speed will work great
    Jun 2015
    Round Rock, TX
    41
    Quote Originally Posted by cowboycasey View Post
    I like the idea of being able to run everything at once if needed. If I get ambitious, maybe an Internet of Things set up to control the speed, turn on fountains, pump through a solar collector for heating Oct/April (night for cooling in the summer?), maybe even misters off the pump! LOL
    Nah, I'll likely just float around and have a margarita.
