Thread: FC went from 7 to 0
    Aug 2016
    Merrick NY
    10
    FC went from 7 to 0
    I used my TF-100 new two days ago. results were as follows:
    TC 2.5
    CC 0
    PH 7.5
    CH 220
    CYA 75
    Salt 2500
    Borate 15
    I added 2 gallons of bleach as per the pool calc and tested it yesterday morning and FC came up to 7. Later that night I added 5 bags of salt. I tested 24 hours later and my FC is 0.5 CC 0.5. Any ideas how I lost so much FC with a CYA of 75?
    What to do next?
    Thanks.
    33k gal, SWG vinyl IGP, free form lagoon, 8' deep end 4' shallow end, Pentair IntelliFlo VS 2hp, AutoPilot SWG, DE filter, Manifold with RC-35/22 cell, Pool Pilot Digital, Gas heater, waterfall, 7 wall returns, 2 bottom returns, 2 skimmer baskets
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: FC went from 7 to 0
    Try an overnight chlorine loss test to see if you have something growing in your pool.
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    Aug 2016
    Merrick NY
    10
    Thanks. I did o an oclt about 5 days ago and it was ok. Should I bring up the FC back to 6 first?
    Jun 2014
    15,032
    You mentioned that you did the OCLT about 5 days ago, but you just got your TF-100 a couple days ago. With a CYA of 75 (round-up to 80) in a SWG pool, your daily FC level is 6 ppm and should never be below 4. Your FC was so low before it's very possible you have algae trying to bloom which is why Isaac-1 suggested a new OCLT. If you still find your FC crashing so much in a 24 hour period, it's probably time to do a TFP "SLAM" (link below).
