Thread: Not sure what plumbing part is needed
    Aug 2016
    Houston tx
    3
    Hello,
    I need some help trying to locate or even part name or number needed to complete the plumbing to pump. The old piece was leaking and I after much struggle it came off ( must have been real old). I need to replace the pvc piece from pump to union sleeve (according to what I've researched I could be wrong).
    Just bought house with first pool and learning a lot! I will attach pictures and below is pool information left buy previous owner. Just not sure how deep the deep end is.
    Water volume: 20,000
    Type: in ground
    Sanitizer used: chlorine
    Surface type: plaster
    Triton 2 sand filter TR-60
    Pentair Challenger high performance pump 1 hp
    Automatic Pentair chlorine in line feeder
    Dy0926
    mas985's Avatar
    Pleasanton, CA
    11,742
    Mark
