Thread: Vacuum head that gets dirt
    Oct 2014
    OKC, OK
    6
    Recently bought a 19" vac head on Amazon to replace original that came with in ground fiberglass pool. It sits about 1/4" off the bottom. It won't suck up dirt except a narrow path right below the hose. I've turned suction up to full (creepy door closed and not sucking). Original head that came with pool didn't have this problem. Suggestions for a vac head that's good at getting dirt?
    This is one I bought on Amazon. Amazon.com : Kokido K894 19-Inch Deluxe Flexible Vacuum Head for Swimming Pools : Patio, Lawn Garden
    Nov 2015
    Ok ok
    823
    Re: Vacuum head that gets dirt
    For what it's worth, I bought one similar to what you show, and returned it. For me just the simple smaller vacuums you can buy at your local markets work better. I think it's just because the smaller the area the greater the suction. You can't cover as much area, but I think it actually is faster using the smaller vacuum because I can maneuver quicker. I can't say that will be the case for everybody but it is for me. Obviously, if you can provide a larger vacuum with sufficient suction it would be better. For me my lines feeding my pump does not allow me to throttle everything to the vacuum. Every situation will be unique to your equipment I imagine.
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    459
    My vacuum head has brushes on the underside.
    I have tried the one you have pictured, and it is good for larger debris , but for the finer stuff, the brushes will loosen it up, so the suction can get it.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Oct 2014
    OKC, OK
    6
    ronsplc. What brand / model do you have with brushes on underside?
