Thread: Steadily Increasing PH
    Jul 2013
    Grand Rapids, Michigan
    55
    I've been struggling keeping my PH in the proper range all season and I'm not sure what I'm doing wrong. I've added Muratic Acid multiple times and it comes down butthen immediately creeps up again. Any advice is appreciated. Test results below.
    FC 4.0
    CC 0.0
    PH 8.3
    TA 150
    CH 280
    CYA 50
    Salt 3800
    Temp 81
    Thank you
    23,200 gallon in ground pool, Vinyl Liner, Salt Water, Variable Speed Pump Intelliflow 3hp/1.32SF/3.96 SFHP, Filter Pentair FNS PLus DE FNSP36, Heater Pentair Mastertemp 250, SWG Jandy APURE35PLG, TF-100 Test Kit
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Re: Steadily Increasing PH
    Hi there
    I strongly reccomend you make an effort to lower your TA. I'd shoot for 80 and see if your PH doesn't stabilize there. If not go a bit lower. It is a process. Pool School - Lower Total Alkalinity
    You'll want to Use MA to lower PH to 7.2 then aerate to bring PH back up then dose again with acid. Keep this process up until your TA is in a better range. Acid reduces PH and TA. Aerating increases PH without affecting TA.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Aimee has it covered. Your high TA is your issue.
    Support the site
    Jul 2013
    55
    Thank you. I'll give it a shot.
