Thread: Appropriate amperage for SWG
    Jun 2015
    Ottawa/Ontario
    340
    Is there a target amperage? What effects the output? As the cell builds scale, will the amperage go down? #confused
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Appropriate amperage for SWG
    There is not a target amperage but there is a range. But it depends on which SWG you have.
    Yes, as the cell builds scale, amperage goes down and so does CL production.
    Mark
