Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Which pool cleaner do you own?
    Jul 2016
    Mamou, Louisiana
    31
    We have owned suction cleaners in the past (KK classic and Great white). KK wore the ink off of the liner at it's usual hangout under the pool ladder and the Great white was afraid of the 6 foot deep end, he liked hanging out by the steps in the shallow end. I had given up on the automatic cleaners and just hand vacuumed for the past 4 years. We are changing our liner in the next few days and thought that, while I'm spending a little money, I may as well spend a little more and try another automatic pool cleaner. The dilemma is...which one to go with? I thought I had narrowed it down to a couple of suction type...Hayward Pool Vac Ultra XL or Pentair Warrior, then my wife stated she was interested in the robots. Could you all help us out by letting us know what type (suction, pressure, robotic) and make/model you have and how long you have had it? I would also like to know what you like about it, what you don't like about it (c'mon, there's gotta be at least one thing that bugs you), and any costs you have incurred for routine maintenance.
    Installed 2004, 16.5 x 32.5 IG Vinyl Grecian, 18K gal, Hayward 1 hp Superpump, Hayward S244T sand filter, Rainbow Lifegard Model 320 Auto-Chlorinator, Intermatic T104P, Hayward 2025ADV Pool Vac XL, Taylor K-2006
    Aug 2014
    Northern IL
    4,615
    Re: Which pool cleaner do you own?
    I have a Maytronics dolphin M3 supreme robot. Supposedly it is too small for my pool, but it works well. It doesn't do the waterline all the way around the pool, but I like to brush my sides manually so I am good with that. I love that it does the job with so little effort on my part.
    The thing I don't like about it is that I have to store it out of the sun to increase its lifespan. That means coiling the wire-thingy and carrying it all into the garage. My vacuum has the same basic issues, as the hose doesn't like the sun either. So that's a wash except that I use my robot a lot more than my vacuum.
    May 2015
    Land O Lakes, FL
    527
    I have a suction size Pentair Sand Shark. I had the choice when building to take a $300 credit or get the vacuum. I wish I took the credit. $300 was about half of a robot that would work great for my small pool inside a screen enclosure.
    The Sand Shark does ok but I don't like to leave it in and don't really need to. The setup, planned to adjust plumming, higher pump speed need and the length of time it requires to hope that it covers the pool leaves much to be desired.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    May 2015
    Jonesboro, AR
    32
    This is my first season with the Hayward tigershark QC. So far it has performed to my expectations. It's easy. Plug it up and put it in. Take it out. Clean filters and it's ready for next time. If your OCD, don't watch it cause it will drive you crazy..😉. One minute it's in the deep end, next it's trying to climb steps, then back to the deep end. It tries to climb too high sometimes so I installed the restrictor plate which it came with. My gripes are it has a hard time climbing steps. Every once in a while it might leave dirt in the liner seam at one particular spot. If it climbs the wall near a corner, it will not go through the corner, ( understandable). If you watch it, you might think it hangs out in one spot too much, but just wait and when it's done, the pool is vacuumed. All that said, I would purchase again. I use the 4 hour setting more than 2 hour. I usually know when we are going to swim and just put it in if needed a few hours before. I bought it at poolzoom.com for around 800.00.
    18x36 Rectangle, 8ft deep end, 26k gallons, vinyl liner, Intellichlor IC40 Chlorinator, 1.5 HP Superflo Pump, Hayward Tigershark QC Robotic Cleaner
    May 2015
    Jonesboro, AR
    32
    Quote Originally Posted by MarianParoo View Post
    I went to Sam's and bought a deck box for our pool stuff. I store it in there after I clean the filters and let them dry for a bit.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Dolphin s300i...all in all I love it. Pros, cleans entire pool in 2.5 hrs (unless we've had a storm). Has a top loading basket that's easy to empty instead of a bag, more cleaning options with Bluetooth AP which I do use at times. I can chose Ultra clean, bottom only, water line only, etc. comes with caddy.
    Cons...doesn't clean entire water line but I clean that myself when in pool so non issue, I have a lot of trees so when there's leaves in the pool it may not get them all but stirs them up instead but still gets 95% of them, when removing from pool and full of water it can be quite heavy for a girl (me) but I'd rather struggle with it than manual vac.
    All in all it's worth every penny I paid for it (($1300)
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I’m going on my 3rd season with an Aquabot Rapids 4wd & I could not be happier!
    We have many trees around the pool and get Pine needles as well as green pinecone leaves that sink right to the bottom of the pool.
    This year I’m dealing with neck & Rotator Cuff issues and I’ve been abusing the Bot every day! It’s like the everyready bunny and gets all the stuff I should be vaccuming & scooping up but can’t.
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Sep 2015
    Rome, NY
    363
    Hayward Bug from the PB when my wife asked for a military discount
    God bless her.
    Works great IMHO
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Jul 2016
    Mamou, Louisiana
    31
    Thanks EVChargeGuy, I guess my main concern with robots is that I have no idea of the maintenance costs. With suction or pressure side cleaners I can repair on my own, where as electronics.....uh, not.
    Jul 2016
    Mamou, Louisiana
    31
    smforte, how long have you owned your dolphin?
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I have an old school Polaris 280....my main complaint is when it gets stuck on the ladder. Other than that it's been great.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2016
    Mamou, Louisiana
    31
    Thanks Defgufman, how long have you owned it and what is the avg annual cost of maintain it? Please read my post in the Pumping Station- "Help...adding dedicated pool cleaner line to existing IG pool". I have been considering a Polaris 280 for some time now but have no dedicated line. Does yours have a dedicated through wall fitting or do you have an over-the-deck connection?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Quote Originally Posted by L'anseMeg View Post
    I've had it 2 months...couldn't be happier. Very well made
    Montgomery, AL
    Quote Originally Posted by smforte View Post
    I've had the S300 since April. It's my second Dolphin and they improved it in every way possible. Runs 3-5 times a week and has been a solid performer.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Dolphin Primal X3. Love it! It does a great job on pool, and I take it out, clean the filters and put it away until the next time. I think this one is one of the lower priced Dolphin products, but it does an amazing job for me.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Jul 2016
    Mamou, Louisiana
    31
    Defgufman you may want to check this out- "Polaris OEM G21 This is a must if you cleaner continually gets jammed up in your Ladder. Set of two durable plastic panels with mounting hardware and Instructions." Roughly 40 bucks online.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Awesome thanks
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I'm not sure what the total cost annually is... I've had the 280 for 3 years. I have it on a timer that runs for an hour at night and 2 hours in the fall when leaves get crazy. It does have a dedicated line that was installed with the pool. So far the only repair costs have been for the sweeper tail sponge.
    Meadow's Avatar
    Jun 2016
    Temecula, CA
    224
    8 months into Maytronics Dolphin Triton with caddy/remote. Runs daily for 3 hrs. Couldn't be any happier
    Maytronics Dolphin Triton Video - YouTube
    20k gallons, IG plaster with raised Spa, Hayward C-4000 cartridge, Hayward TriStar SP3202VSP, Hayward H400 gas heater, Hayward Super II (2HP) Spa jets, Hayward Swimpure Plus T-15,
    Intermatic PS3000 SPD, PureLine-PureColor LED's, Dolphin Triton cleaning robot, Taylor K-2006, K-1766, OTO Test kit & various Guess strips.
  20. Back To Top    #20
    The majority of robots come with 2 or 3 year warranties. Beyond that, parts like treads and brushes are available and not very expensive (at least for current generations). I have a Dolphin that's at least 15 years old and still has its original parts -- the power supply, on the other hand, was awful, as was the case with the older-style power supplies. I can't vouch for the lifespan of the current power supplies as I'm in my first 4 months of ownership, but they seem to have made improvements.
    Geebot
    Chicago, IL
