Thread: Looking for a PVC straight thread fitting
    Apr 2015
    South Central PA
    297
    I'm looking for a 2" adapter fitting with straight thread, as opposed to the tapered pipe thread....I think the threaded winterizing plugs have straight threads, but I need something like this: Shop LASCO 2-in Dia PVC Sch 40 Adapter at Lowes.com except straight thread...I tried searching Hayward products, but I don't see anything. I think if it exists, it's a pool part.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Looking for a PVC straight thread fitting
    Electrical conduit is usually straight thread. I use them to DIY bulkhead fittings.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2015
    South Central PA
    297
    Thanks...I heard that somewhere else and bought an electrical conduit fitting, but it turned out it was tapered as well...I checked it with micrometers and a straight edge. I'll have to see if there's another one available elsewhere.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    In my area, Home Depot usually has the straight thread. Lowes switched to both being tapered.
    Apr 2015
    South Central PA
    297
    That's helpful- thanks. I bought my part at Lowe's, so I'm going to check HD now.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    look also at the supply houses catering to your local electrical contractors.
