Thread: fiberglass pool stains
    May 2009
    Trenton NJ
    497
    I have a 20,000 gal inground fiberglass pool and tha past couple years we had problems with staining. The walls are stained,just looks like they are dirty. We brush all the time but they remain on the walls. Any idea's, help would be appreciated.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: fiberglass pool stains
    Well, it could be a few things, but I suspect its from the N2.
    You need to test the stain with Vitamin C tablet or Dry Acid in a sock...
    Read these three articles:
    http://www.troublefreepool.com/alter...uth-t3025.html
    http://www.troublefreepool.com/ascor...ins-t2298.html
    http://www.troublefreepool.com/pool-...metal%20stains
    Hope this helps. Be prepared, there's a lot of info there, I don't mean to overwhelm you.
    May 2009
    Trenton NJ
    497
    Where can you buy ascorbic acid by the pound and also poyquat 60?
    11,969
    Quote Originally Posted by ethany
    There are links in the second article I posted above, for AA. Also PQ 60 can be purchased online or at the pool store, just make sure it's PQ 60 and not a substitute.
    You need to confirm what the stains are before you go down that road, if it's copper that process won't help, and might make the stain worse.
