Thread: If going on vacation for 7 days, should I load up my pool with chemicals before?
    Jun 2016
    Western Connecticut
    47
    Hi. Here are the readings:
    FC: 9
    CC: 0
    CYA: 90
    I think I lose around 1 ppm of FC per day (although I have not done the FC loss test on the site here).
    I am going on vacation for 7 days and no one will be using the pool. Before I leave, should I up the FC to 16, on the assumption that it will be back down to approximately 9 when I return?
    What do people typically do when they go on vacation? Thanks
    32,500 gallon in ground Gunite/White Plaster, Pentair Cartridge Filter, Pentair Propane Heater, Pentair Racer robot cleaner
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: If going on vacation for 7 days, should I load up my pool with chemicals before?
    My pH tends to rise so I lower it to 7.2. I raise FC up to shock level for my CYA, FC/CYA Chart. Chlorine drop isn't that linear. The higher it is the more it tends to drop.
