Results 1 to 10 of 10
Thread: Need socks for extra large skimmer
    Jul 2015
    Cape May Court House, NJ
    121
    I have what must be an extra large skimmer basket. The outer edge of the top rim is 9.5". Skimmer socks I've bought at the pool store don't even come close to stretching across. Does anyone know of an extra large sock that I can get online?
    I've also seen posts from people who are using nylon stockings. My wife says I'll never find a stocking with a leg opening that big, but that pantyhose might work. If I use that, what do I do with the legs? Can I cut them off and tie up the opening?
    Any suggestions are appreciated!
    22K 16'x40' inground fiberglass pool, Hayward Pro Series High Rate Sand filter, Hayward dual speed 2 hp Super II Pump, Hayward AquaRite SWG, Raypak 400K btu propane heater, Dolphin Supreme M400 cleaning robot, CoverPool auto cover. Also stand-alone Sundance Hawthorne 430 gallon hot tub.
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    Re: Need socks for extra large skimmer
    I wonder if the disposable hair nets that folks have been buying on Amazon might not be a better fit?
    Just showing this the pic-there are cheaper ones on Amazon. 3M Disposable Hair Net 407, Spunbond Polypropylene, Universal, White (Case of 100): Amazon.com: Industrial Scientific
    Jul 2015
    121
    Thanks, Yippie Skippie – great to hear from you! I think I'll give the hair nets a try.
    Has anybody out there had success with them?
    Aug 2014
    Houston tx
    2,524
    I use them all the time. No issues. But my skimmers are the normal size. I do use my skimmer socks for chems that need to be hung into the water.
    I think you should be able to use the hairnets in a larger skimmer. They have lots of stretch.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jul 2015
    121
    I checked out the link on Yippee Skippy's post and they're 11" wide, so it looks like they'll fit. Even though they seem to be marketed for hospitals and chemical labs, most of the customer reviews I read were from people using them on pool skimmers, so I guess that's a good sign! I ordered them and they'll be here on Monday. I'll post a follow-up then and let you know how well they work.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    I found a big strainer sock at my local Ace hardware. It's intended to go on a 5-gal bucket so it should be big enough if the hairnet doesn't do the trick for you.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    121
    Thanks pabeader! Apparently I'll know by tomorrow afternoon.
    Aug 2016
    Tipton Co, TN
    9
    Quote Originally Posted by pabeader View Post
    Paint strainer sock? Never thought about it, but one of those would work pretty well.
    33' Round AGP (28k-ish gallons)
    1.5HP pump w/Hayward VarifloXL/SwimPro Sand Filter
    K2006
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    The paint strainers work well, but hair nets have the advantage of being disposable and straining finer. If the standard hairnets don't fit, there are larger ones. Look for extra large or bouffant ones.
    chiefwej
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    The hair nets are the way to go, IMO anyway!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
