Thread: High alkalinity in pool
    Aug 2016
    Reno NV
    16
    I have a 10 x 30 Intex easy set pool 1019 gallons. I've been testing my water daily with the hth 3 way liquid test kit for chlorine and ph. My ph was slowly dropping so I used my hth test strips to test everything, specifically TA. It was hardly registering 80 so I used the pool calculater to see how much baking soda to put in to bring it up to about 110. Well the next day I tested again, first with my liquid drops to get my ph and it is spot on. I then used my strips and it was still showing the same results. I wasn't believing it so before doing anything else I went and bought the hth 6 way liquid test kit. I tested my TA again and it is now 170. It's been like this for 2 days now but my ph is staying stable. So I'm thinking my test strips are bad and my TA was probly fine to begin with. So my question is do I need to lower my TA or can I leave it as long as my PH is staying stable? If it does need to be lowered, I'm not really interested in adding more chimicales if I don't have to since it is such a small pool, so would doing a partial drain and refill help?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: High alkalinity in pool
    Welcome to TFP.
    TA is the very last thing we worry about, and then only if the pH is unmanageable.
    Throw the test strips away. They are generally worthless.
    Support the site
    Aug 2016
    Reno NV
    16
    So it's ok since the ph is staying at good levels?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Yes, if PH isn't rising too much then it is fine to leave it. If PH rises too much you can lower TA to help slow pH rise.
    Aug 2016
    Reno NV
    16
    Thank you so much!!
