Thread: Bypass 3way valve help
    FirstVallartaPool's Avatar
    Apr 2016
    Puerto Vallarta mexico
    109
    I am not able to source a 3way valve here in vallarta. I am trying to add a bypass to the heat pump as it's only used for a couple months. Would it be ok to put 4 shutoff valves before and after connections in and out of heater or would that ristrict water flow when heater is shut out? I could always not put a Bypass as heatsiphon says it's a flow through design and a bypass is not needed. Any suggestions or input. Thanks!
    Pool 3800 gaĺlon glass tiled concrete approximately 10 years old/ Puerto Vallarta
    Hayward sand filter S166t.
    Pool Pump Silver10/1115 1hp
    Heat siphon Sx3.25hp
    Hard Municipal Water tf-100 test kit
    38,452
    Re: Bypass 3way valve help
    You can add a bypass with 3 shutoff valves, ideally pool valves like the Neverlube. One on the heater inlet and outlet and one on the bypass to force water through the heater.
    Apr 2016
    109
    Im trying to picture what youvare describing but not clear. Can you explain further. Thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Apr 2016
    109
    Got it thanks. Do you think its worth doing or should I just leave out as recommended by heatsiphon support?
    DFW, TX
    24,502
    I think it is a good idea to have a heater bypass.
